WD-40 as rubber trim protectant & window lubricant ? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-04-2007, 04:17 AM Thread Starter
tmfoo's Avatar
Date registered: Aug 2007
Vehicle: 1997 SLK200, 1999 Toyota Camry 2.2
Is it a good idea to use WD-40 to lubricate / protect the rubber trims for the windows ? I think i should do something proactive considering the year-round tropical sun here.
tmfoo is offline
post #2 of 11 (permalink) Old 11-04-2007, 05:53 AM
rpiotro's Avatar
Date registered: Sep 2007
Vehicle: 2012 SLK350
Quoted: 4 Post(s)
I don't think that wouldd be a good idea. I believe WD40 is petroleum based. It would probably slowly dissolve the rubber.
I found DuPont Krytox to work extremely well! I applied it to the rubber seals on my SLK and it stopped the creaks and squeaks.
http://www2.dupont.com/Lubricants/en...qs_krytox.html
http://www2.dupont.com/Lubricants/en...ak_rattle.html
http://forums.vwvortex.com/zerothrea...ostid=33268064
http://www.thtgroup.com/krgpl205gr.html
Krytox can be used for many purposes. Brake caliper lube, dielectric grease or almost any place that you need a long lasting, high temp lubricant. It is expensive but, a little goes a long way.
Rich Piotrowski
rpiotro is offline
post #3 of 11 (permalink) Old 11-04-2007, 08:07 AM
berk's Avatar
Date registered: Oct 2005
Vehicle: 99 slk230 sport
i amnot sure if wd contains petro, but the base for it is actually fish oil. thats why it works for bait! i use tire foam to clean and lube the seals on my car.
berk is offline
post #4 of 11 (permalink) Old 11-04-2007, 03:59 PM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
I'm sure WD 40 is not good for rubber nor is any silicone based product - Have a read of this
That stuff recommended by rpiotro is great for roof rubbers and 303 protectant is great for rubber trim and vinyl (or any treatment with plasticisers in it)
Oberoi
oberoi is offline
post #5 of 11 (permalink) Old 11-04-2007, 04:41 PM
page62's Avatar
Date registered: Aug 2003
Vehicle: 2001 SLK320, 2001 C320
Oberoi
Correct. Forget the WD-40, and find yourself some 303 Protectant. It's the best!
Current: 1989 300E
Past: 2001 SLK320, 2001 C320, 1979 450SL
page62 is offline
post #6 of 11 (permalink) Old 11-04-2007, 05:12 PM
SLacKer-320's Avatar
Date registered: Jan 2007
Vehicle: '01 SLK-320
Silicone spray works well also.
'01 SLK-320 - Black & tan. Bone stock.
SLacKer-320 is offline
post #7 of 11 (permalink) Old 11-04-2007, 07:26 PM
Date registered: Jun 2006
Vehicle: 1998 slk230
Oberoi
I'm no chemist, but I wouldn't think silicone based products would cause a problem. For scuba-diving equipment, it's common for people to spray down there very expensive breathing apparatuses with food quality silicone spray to keep the rubber gaskets, seals, and diaphrams in good condition. Note, these seals are of life/death importance, so I'd think someone had done their research early on on this one.
Besides, I'm suspicious that the documentation posted here is posted by a company that has financial interests in your buying their expensive 303 stuff. Not to say it isn't good though!
Joe
Seattle
1998 slk230
koaea is offline
post #8 of 11 (permalink) Old 11-04-2007, 07:51 PM
ALephart's Avatar
Date registered: Dec 2006
Vehicle: 1998 SLK 230 KOMPRESSOR
Send a message via AIM to ALephart
Just bought some 303 on fleabay.
Aaron Lephart
www.techvelocity.com
SLK32 Front/rear calipers and rotors
Hawk EP + pads
ATE fluid
Stoptech lines
AMG 17'' sport rims with Toyo T1R's
ASP 10% overdrive pulley, Bosch FR5DC plugs, fuel pressure riser
LED interior lights.
KONI adjustable shocks
Ceramic coated exhaust manifold and valvecover.
NEW OEM black interior
Simpleroof
ScanguageII
Projector beam headlamps
4500K Xenon/HID headlight bulbs
Sprintbooster
CLK style grill
OEM SL antenna color matched
Dynamat
ALephart is offline
post #9 of 11 (permalink) Old 11-05-2007, 05:36 AM
page62's Avatar
Silicone causes problems over time. Just ask anyone who's put too much Armor All on their cars! On the other hand, 303 Protectant doesn't have silicone, so it doesn't build up, become greasy, etc. I've used it for many years on boats, and their claims are true.
Perhaps food-quality silicone is OK...but I've no experience with it personally.
Current: 1989 300E
page62 is offline
post #10 of 11 (permalink) Old 11-05-2007, 05:48 PM
TheJimbo's Avatar
Vehicle: 2008 ML350; 2001 SLK230 (traded in)
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is offline
Need a source for rubber trim. Wagon Train W210 E-Class 0 11-16-2006 07:35 AM
Getting wax out of rubber trim peter811 Detailing and Car Care 3 11-24-2005 07:39 PM
ML rubber window trim molding,losing its flat finnish,HELP rand W163 M-Class 5 12-25-2002 11:58 PM
Treating Weather strip & seals with Silicone lubricant ushafiq W163 M-Class 1 09-10-2002 03:36 PM
Treating the rubber window surround trim, Drew u inspired me to treat it :) AlBoston W163 M-Class 17 08-23-2002 06:55 AM
