» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 10-29-2007, 02:26 PM   #1 (permalink)
Date registered: Feb 2005
Vehicle: 1999 SLK230
Replaced Battery - What happened?
I replaced the original battery in my SLK230 with another MB battery. I knew I would need the code for the radio. But several other strange things happened when starting the car.
The Fuel and Temp gauges are not correct; the fuel gauge actually spins all the way around. The outside temp is incorrect and now is Celsius. And the odometer is all dashes now(-------).
Any ideas what has happened? Does something have to be reset? For now I think I will check the fuses.
mitchshin is offline   Reply With Quote
Old 10-29-2007, 02:45 PM   #2 (permalink)
slk230280's Avatar
Date registered: Apr 2006
Vehicle: 2003 slk230
Did you leave key in ignition?
slk230280 is offline   Reply With Quote
Old 10-29-2007, 04:32 PM   #3 (permalink)
page62's Avatar
Date registered: Aug 2003
Vehicle: 2001 SLK320, 2001 C320
Ummm...you don't want to hear the answer to this one...
(Hint: Do a search.)
<a href="http://www.wunderground.com/US/TX/San_Antonio.html?bannertypeclick=miniWeather2">
<img src="http://banners.wunderground.com/weathersticker/miniWeather2_both_cond/language/www/US/TX/San_Antonio.gif" border=0
</a>
page62 is offline   Reply With Quote
Old 10-29-2007, 04:40 PM   #4 (permalink)
I did have the doors closed and no key in the ignition. I guess I need to look for an instrument cluster. I just don't understand why you have to take a chance of blowing the panel whenever the battery is changed. How could this be avoided?
Old 10-29-2007, 05:08 PM   #5 (permalink)
oberoi's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2000) C180/230E/280SE
There's an anti zap device from Matson that fits across the terminals - pics if you search
Oberoi
oberoi is offline   Reply With Quote
Old 10-29-2007, 06:08 PM   #6 (permalink)
AMPM's Avatar
Date registered: Sep 2003
Vehicle: SLK 230
Send a message via ICQ to AMPM
Anti Zap Protector
I Drive Route 4, Southern Maryland's Autobahn.
Slower Traffic Keep Right!!
AMPM is offline   Reply With Quote
Old 10-29-2007, 06:47 PM   #7 (permalink)
berk's Avatar
Date registered: Oct 2005
Vehicle: 99 slk230 sport
this is unacceptable engineering on benz part. how can a simple battery swap kill the car? why didnt they simply install a anti zap at the factory? could this be avoided by draining the battery slightly before installation? (im lazy and cheap)
berk is offline   Reply With Quote
Old 10-29-2007, 08:15 PM   #8 (permalink)
Date registered: Sep 2006
Vehicle: 2002 SLK32AMG and 2001 SLK230K
Send a message via ICQ to Ryououki Send a message via AIM to Ryououki Send a message via MSN to Ryououki Send a message via Yahoo to Ryououki Send a message via Skype™ to Ryououki
AMPM, that negative ground clamp on your battery is awesome. Never seen one with a built in voltage read-out. Is it an always on thing or does it on come on when you push a button? Where did you get it?
Ryououki is offline   Reply With Quote
Old 10-30-2007, 03:45 AM   #9 (permalink)
TheJimbo's Avatar
Vehicle: SLK230 (2001)
Agree, it's bullcrap on M/B's part.
I have the same anti-zap installed on my SLK as AMPM does. It was inexpensive, easy to do, and gives great peace of mind. Do it.
2001 SLK230 Kompressor
2001 Dodge Dakota Quad Cab 4x4
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is online now   Reply With Quote
Old 10-30-2007, 04:39 AM   #10 (permalink)
How does the Antizap work when I am actually changing out the battery, since this is when the damage usually occurs? Does the device remain connected to the cables before they are attached to the battery?
Installing a car battery is a pretty simple procedure on any other car. I have seen no information from MB pertaining to any special procedures when installing the battery. When I purchased the battery, no one at the dealer made any comments. The Techs I spoke to seem unaware of the issue, which is hard to believe. Of course, most owners are not even aware of the problem until after the fact. I am blown away by the number of SLK owners that have experienced the exact problem over the past few years.
I wonder how MB would have handled this if they were the ones to do the battery install. Would they try to get over $1000 from me to replace the cluster?
I think I will write to MB to see what their official response is to the matter. I would think this is something in need of a TSB or even a recall.
Battery Replaced no Radio working RMM57 Audio & Telematics Forum 1 01-13-2009 11:12 AM
Replaced battery today and...... Neekster W208 CLK Class 3 09-22-2007 09:17 PM
The problem after replaced the old battery 05GLI W210 E-Class 0 07-04-2005 06:24 PM
'91 300D Changed battery, stuff happened allpoints360 W124 E,CE,D,TD Class 1 05-04-2005 08:17 AM
Just had my Battery replaced under warranty dhughes R170 SLK Class 0 02-19-2003 04:45 AM
