Door panel and lock/latch assy removal - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 08-11-2007, 01:11 AM Thread Starter
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Had to change out the lock/latch assy today.
remove inside pull handle
remove screws
remove trim
unplug tweeter connector
undo door pull
remove other trim pieces
loosen handle stop 4mm hex key(left hand door turn to left pull handle and turn back, right hand door turn to right , pull handle and re tighten just a bit)
undo 2 x T30 holding in window slide
remove lock assy (4mm hex screw stays in hole)
pull off vac line (if reusing and connector braks super glue will fix ok (past experience)
manouver assy out thru hole in door.
replace in opp order
when putting handle back in turn 4mm hex as before. When handle seated tighten carefully remember left is clockwise , right is anticlockwise
re att handle pull
lower trim onto door (maneuver lock pin thru hole)
press studs into holes
replace handle and trim pieces
Bazzle
Bazzle is offline
post #2 of 15 (permalink) Old 08-11-2007, 01:14 AM Thread Starter
Bazzle's Avatar
And more
Bazzle is offline
post #3 of 15 (permalink) Old 08-11-2007, 01:18 AM Thread Starter
Bazzle's Avatar
And more
Bazzle is offline
post #4 of 15 (permalink) Old 08-11-2007, 01:20 AM Thread Starter
Bazzle's Avatar
Bazzle is offline
post #5 of 15 (permalink) Old 08-24-2008, 01:45 AM
230_tyreso's Avatar
Date registered: Feb 2006
Vehicle: SLK230
Hi All
When I try to follow the instructions above it seems as if the "carbon fibre" piece (where the chrome opening part for the door ) is stuck and wont allow for the door panel to lift upwards. Does anyone know how to proceed beyond this part when removing the door panels? I don't dare to proceed in case I muck up something it seems really stuck.
I am in the process of installing a new sound system and documenting it with pix but I am stuck here near the final moment and it is very frustrating having ripped out the rear interior for rear speakers / sub woofer / CD changer and now have the door speakers left.
I love to hear your advice on these door panels.
Cheers
Chris
SLK230_99_Tyreso
230_tyreso is offline
post #6 of 15 (permalink) Old 11-30-2008, 02:38 PM
DarkHalo's Avatar
Date registered: Aug 2008
Vehicle: Silver/Black 2002 SLK320
EXCELLENT instructions above! I had been putting off pulling the drivers side door panel but it is amazingly easy. The other day I pulled the door closed and about half of the door panel came off in my hand. Long story short someone had put in three #12 screws where they should have used #14's. I put in the proper screws, used some Liquid Nails on the seperated door panels and it looks new and is as solid as a rock. Thanks Bazzle!
2002 SLK320 (I love this car)
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf" - George Orwell
DarkHalo is offline
post #7 of 15 (permalink) Old 03-16-2010, 12:53 AM
Date registered: Sep 2009
Does anyone know the exact part numbers for the parts shown in picture P1010047 (Medium).JPG? I am referring specifically to the plastic handles (face and back) that together form the actual handle you use to pull the door when you are inside the car (not the shiny little handle you use to open the door). I tried looking for the parts using keywords like "grab handle", "pull handle", "door grab", etc and couldn't find the part numbers. The dealer knows exactly what part I am talking about but he won't give me the part number - he wants me to order from him instead of looking for the part online, which is exactly what I am planning on doing...
csgyuricza is offline
post #8 of 15 (permalink) Old 06-25-2010, 11:48 AM
Date registered: Mar 2010
did you ever find the replacement parts for the door pull?
I would love to upgrade mine if I can find something better, otherwise I'm repainting them shortly.
MMSanJose is offline
post #9 of 15 (permalink) Old 06-26-2010, 02:51 PM
Date registered: May 2009
Vehicle: 1999 SLK 200K
See this file http://www.buellwinkle.com/SLKParts.pdf from leapyfish signature.
Page 1075
filtragem is offline
post #10 of 15 (permalink) Old 05-01-2011, 05:01 PM
geordie's Avatar
Vehicle: 2002 SLK32AMG,1995 E320 Cab 1990 300CE(Gone).2002 ML320 (Gone)
Quoted: 16 Post(s)
A few comments on door lock removal - later SLKs
It's great to have this forum as a resource.
I just replaced my driver side door lock and I couldn't have done it without Bazzle's outstanding description and pictures.
My car is a 2002 and there is a major difference to the earlier SLKs in respect of the doors.
The MB manual and Bazzle both specify the need to remove the window guide in order to remove the lock.
On my car the window guide isn't there ! Trust me, I looked for it. I suspect that the later R170 models have a different power window mechanism.
What I ended up doing was as follows:
The lock has a clip on plastic dust cover: by removing the dust cover from the lock mechanism whilst still in the door I managed to get the separate parts out without removing the power window hardware. Similarly I unclipped the dust cover from the new lock and managed to squeeze the 2 pieces into the cavity before re-assembling them inside the door.
Also not mentioned in the forgoing description is the wiring connector for the lock limit switch - again I suspect this was added to later R170s. This connector latches into the socket on the lock.
Once again, thanks to Bazzle.
Geordie
VA USA
2002 SLK32///AMG
1995 E320 Cabriolet
geordie is offline
97 V230 rear door inner door card/panel removal ziras V-Class 6 02-27-2007 01:01 PM
ML 320 right rear Door Latch "machine gun lock effect" nlingala W163 M-Class 2 06-22-2005 03:17 PM
Door panel removal W126fahrer W126 S,SE,SEC,SEL,SD,SDL Class 12 09-21-2003 04:22 PM
door latch removal GDJ W126 S,SE,SEC,SEL,SD,SDL Class 0 03-04-2003 06:32 PM
Door panel removal Dave L. W163 M-Class 11 11-21-2001 09:06 PM
