» Site Navigation
» Other Sites
Old 07-26-2007, 08:25 AM   #1 (permalink)
Date registered: Jul 2006
Vehicle: 1998 SLK 230
trans fluid and diff fluid replacement cost?
How much should I expect it to cost to replace transmission fluid?
How about diff fluid?
1998 SLK 230, 103k miles
Alexandria, VA
numitor is offline   Reply With Quote
Old 07-26-2007, 12:14 PM   #2 (permalink)
Date registered: Nov 2006
Vehicle: 1999 SLK 230 Kompressor
I had my trany service done in LA at Keyes' Mercedes for $200. Well worth it....
RichSLK323 is offline   Reply With Quote
Old 07-26-2007, 01:06 PM   #3 (permalink)
slk230280's Avatar
Date registered: Apr 2006
Vehicle: 2003 slk230
How many quarts of trans fluid they put in?
slk230280 is offline   Reply With Quote
Old 07-26-2007, 01:32 PM   #4 (permalink)
I have no idea...but the service included replacement of all the fluid...resetting of the shifting parameters, changing of the pan...
Old 07-26-2007, 01:44 PM   #5 (permalink)
Date registered: May 2005
Vehicle: 2001 SLK 320
Get up under there and do it yourself- All you need is a new gasket and filter (around $30) and 4 quarts of ATF+4 from Autozone ($3.68 a quart). Don't be tricked into thinking you have to use that special MB Trans Fluid.
prtdvl is offline   Reply With Quote
Old 07-26-2007, 03:42 PM   #6 (permalink)
slk230280's Avatar
Prtdvl, how long/miles have you been using ATF+4?
Old 07-26-2007, 04:02 PM   #7 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
It takes 7 qts (some people get away with 4 because they forget to drain the torque converter). Also the cost of the filter and such, it would set you back about $150 at the parts counter. Getting it done for under $200 is a good deal and worth it. The rear dif is easier although messier and smellier, have a shop do it, I paid about $30. These are jobs that are not fun without a lift and don't have a good enough value proposition. For example I paid 180 to have the tranny fluid done, it's not worth $30 to get under the car and risk my life or worse, the tranny. Imagine messing it up and paying $3,500 for a tranny rebuild.
Old 07-26-2007, 04:51 PM   #8 (permalink)
Date registered: Oct 2005
Vehicle: 1999 SLK230
there is an excellent procedure for changing the differential fluid at slk32 com. Costs about $16 for the fluid. I just did mine for the second time a couple of weeks ago. Takes about 20 min.
upstate engineer is offline   Reply With Quote
Old 07-28-2007, 06:54 PM   #9 (permalink)
K. Boo's Avatar
Date registered: Jun 2005
could use your opinions on my transmission fluid change cost...
So, since my car was approaching 70K miles and listening to the posts about the "need" to change the AT fluid and I also noticed sometimes my car wasn't shifting out of first gear as it should; I inquired to my Benz Service about the cost to change the fluid, filter and check the diagnostics to see if there was anything they could tell me about the not shifting out of first gear problem. Initially, I got the "fluid is in their for life" line. When I asked them to double check their guidance and if they would would change it if I really wanted them to change it. The dealer said for $399. USD they would change the fluid, filter, use a new gasket on the pan and it would include their "minimum hour of labor" ($125.00/hour) to run the diagnostics to see if it showed any codes indicating any computor related transmission problem. When I dropped the car off, in their printed brochure of "A La Carte Services" at the service desk, there was listed an automatic transmission fluid and filter change for $169.95 USD (Called out as every 36 months or 39,000 miles) When I asked about the difference in price from the brochure to what I was quoted, they said, "that wasn't for my car." They could not tell me what Mercedes car it was for... "but it must be for older models." Anyway, right or wrong, I went ahead and told them to do the service. They came back with no error codes on the diagnostics and the said the fluid was really fouled, so at least I am glad I went ahead with the fluid change.
'02 Black SLK 230, AT
'99 Firemist SLK 230, AT- Sold
K. Boo is offline   Reply With Quote
Old 07-28-2007, 08:27 PM   #10 (permalink)
oberoi's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2000) C180/230E/280SE
Don't feel too bad K. Boo, they could only afford to do that $169 change on an older Benz using the older and much cheaper ATF fluid
Yours needs the much more expensive synthetic fluid
oberoi is offline   Reply With Quote
Diff Fluid to Use? TheJimbo R170 SLK Class 4 06-16-2007 07:13 AM
How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 14 08-17-2006 04:31 PM
How often do you change your Diff. Fluid? Minkoff W126 S,SE,SEC,SEL,SD,SDL Class 2 02-23-2006 11:24 AM
Where do you guys get your trans fluid replacement kit? ninjamonkey W140 S-Class 4 07-09-2004 03:58 PM
rear diff fluid Guest (MBNZ) W201 190E, D-Class 5 06-19-2002 07:14 AM
