Old 06-21-2007, 02:07 PM   #1 (permalink)
Date registered: Jun 2007
Vehicle: slk 230 99 amg setup
DIY MAF Cleaning
Anyone have a DIY for MAF cleaning.... I just dont want to do anything wrong....
you guys are awesome...
Paul
slk230paul is offline   Reply With Quote
Old 06-21-2007, 02:27 PM   #2 (permalink)
television's Avatar
Date registered: Sep 2005
Always a hard question as to if will work.
there are three types of elements in these things yours will be one of the later sensor type and the chances a small at a clean being effective.
It can be cleaned with any alcohol based solvents, In the UK we use IPA 170 by Servicsol
If you need a new one, go the your Bosch dealer where they are half the price of getting one from MB
Malcolm
SL500 with ever known extra
television is offline   Reply With Quote
Old 06-21-2007, 02:41 PM   #3 (permalink)
page62's Avatar
Date registered: Aug 2003
Vehicle: 2001 SLK320, 2001 C320
Please fill out your profile. Answers will vary depending on the year of your car, and where you live. It's a big help!
For example, US/Canada owners would use CRC MAF Cleaner.
Check with Bazzle, I think he's written a procedure...
<a href="http://www.wunderground.com/US/TX/San_Antonio.html?bannertypeclick=miniWeather2">
<img src="http://banners.wunderground.com/weathersticker/miniWeather2_both_cond/language/www/US/TX/San_Antonio.gif" border=0
</a>
page62 is offline   Reply With Quote
Old 06-21-2007, 03:35 PM   #4 (permalink)
penbed51's Avatar
Date registered: Jan 2006
Vehicle: 2001 SLK230
Paul
Two things;
!. Look at the tech sticky
2. Do a search in forum for MAF cleaning
You can bet Bazzle will have something posted,usally with pics.
penbed51 is offline   Reply With Quote
Old 06-21-2007, 05:16 PM   #5 (permalink)
TheJimbo's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2001)
Pretty straight forward.
1. Remove MAF (torx screws).
2. Spray liberally with CRC MAF Cleaner - do not touch metal elements with fingers!
3. Let air dry, and/or shake dry (again, do not touch elements).
4. Replace (make sure it's dry first).
5. Open bottle of beer.
6. Consume contents.
Worked for me!
2001 SLK230 Kompressor
2001 Dodge Dakota Quad Cab 4x4
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is offline   Reply With Quote
Old 06-22-2007, 12:36 PM   #6 (permalink)
lcdial's Avatar
Date registered: Jun 2006
Vehicle: 2001 SLK320 - Red, Magma Red
Here is a photo-guide for a V6:
Photo Guide
It's very easy -- especially if you follow TheJimbo's 5th and 6th steps as steps 1 -6.
lcdial is offline   Reply With Quote
Old 06-22-2007, 08:16 PM   #7 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
You will need torx security/tamper proof bits. Use CRC MAF cleaner only!!!
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 06-22-2007, 11:26 PM   #8 (permalink)
thanks guys...
will try beer first then beer after.....awesome
Old 06-23-2007, 01:57 AM   #9 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
To clean MAF.
Ign off.
Remove connector off MAF (squeeze tag and pull)
Either remove sensor only or remove whole housing.
To remove housing undo hose clamp and wiggle hose off.
Undo 2 overcentre clamps on housing and wiggle out of seat
To remove sensor remove 2 torx screws (may be 5 or 6 point scurity torx)
If you dont have a tool undo with small locking pliers and replace with normal self + head tapping screws to make later removal easy.
Spray liberally with maf or contact cleaner so it drips out with contaminants and shake dry. DO NOT use compressed air.
If housing removed now is a time to wipe out the oil film with a lint free rag.
Also remove oil seperator from top of engine and spary to clean it too if tubes oily.
Replace all parts. (smear of oil will help seat sensor and housing into their seats, ensure 'O' rings secure.
Start engine to ensure it idles and adapts.
If engine wont respond to accelerator try this..
Keys out
Start engine
Hold brake pedal down hard
Put in drive
Leave to idle for a minute
Put in park
see if engine responds to throttle pedal.
Bazzle
Bazzle is offline   Reply With Quote
Old 06-24-2007, 01:47 PM   #10 (permalink)
Date registered: May 2005
Vehicle: 2001 SLK 320
Cleaned mine, still rough idle.
Seems to be not much improvement- car has 83k, had plugs and air filter changed at 77k. Could this be the fuel filter?
prtdvl is offline   Reply With Quote
Cleaning the MAF sensors..? Seems that we don't need to be buying MAF sensors all the time..? AC_ML W163 M-Class 11 01-30-2008 04:49 AM
Cleaning MAF? Designo_E320 W210 E-Class 18 05-16-2007 12:39 PM
MAF Cleaning dlafever W140 S-Class 11 05-11-2007 11:40 AM
Maf Cleaning? Dolphin27 R170 SLK Class 4 01-30-2007 07:06 AM
anyone have diy-info on MAF cleaning? ProV1x W210 E-Class 2 11-30-2006 06:07 PM
