1998 SLK 230 How to change the tranny oil? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-08-2007, 01:40 PM Thread Starter
Date registered: Jan 2007
Vehicle: 1998 SLK 230 Kompressor
Hello again all,
yes it is your rookie SLK230 owner once again with help questions. I need to know how to change the tranny oil in my 1998 SLK 230 5speed auto. I know you must use the Magic Oil, gaskets and filter from the dealer. I found the dip stick on ebay. So, all I need to know is there any instructions anywhere on the forum or internet? Is there any special tools or tricks I need to know. Any help would be greatly appreicated. I do not want to have to purchase a new transmission.
Thanks for your patience and help.
John
jmorino is offline
post #2 of 8 (permalink) Old 06-08-2007, 01:42 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Bazzle is offline
post #3 of 8 (permalink) Old 06-08-2007, 01:45 PM
Bazzle's Avatar
Bazzle is offline
post #4 of 8 (permalink) Old 06-08-2007, 05:34 PM
SLacKer-320's Avatar
Vehicle: '01 SLK-320
Originally Posted by Bazzle
Remove transmission, tip on end, drain oil out.
Bazzle
I like: "Get power drill with carbide drill bit. Drill hole in bottom of transmission case. Drain out old oil. JB-weld hole shut. Add new oil. Done."
'01 SLK-320 - Black & tan. Bone stock.
SLacKer-320 is offline
post #5 of 8 (permalink) Old 06-08-2007, 05:56 PM
AMPM's Avatar
Date registered: Sep 2003
Vehicle: SLK 230
http://www.benzworld.org/forums/r170...ans+oil+change
MercedesShopWiki: 722.6 Transmission Fluid and Filter Change
Use this link.
I Drive Route 4, Southern Maryland's Autobahn.
Slower Traffic Keep Right!!
AMPM is offline
post #6 of 8 (permalink) Old 06-08-2007, 10:19 PM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
Good luck with it jmorino, - your model should have the drain on the torque conv. which is a real plus!
Think about putting a magnet in the pan - I think they put one in later.
Use loctite on the 6 bolts - peace of mind!
Oberoi
oberoi is offline
post #7 of 8 (permalink) Old 06-13-2007, 04:18 PM Thread Starter
OK, I removed the Tranny and drained the oil. Boy, it was a little heavy. Now, how do I get the tranny back in????
jmorino is offline
post #8 of 8 (permalink) Old 06-13-2007, 05:03 PM
Bazzle's Avatar
It lighter with no oil so you shouldnt have a problem
Bazzle
Bazzle is offline
    1998 Slk 230 F.s. Benzkid27 R170 SLK-Class 0 05-28-2007 04:35 PM
    Oil Sender for 1998 SLK 230 benkokes For Sale/Wanted/Trade/Giveaway 0 10-26-2006 08:54 AM
    Help with Tranny oil change. rramsa01 R170 SLK-Class 15 06-15-2004 12:45 AM
    1998 SLK 230 pina84 R230 SL-Class 2 08-21-2003 10:39 PM
    1998 SLK 230 I just bought. What engine oil should I use? Jack R170 SLK-Class 2 11-06-2001 08:01 PM
