» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 06-22-2007, 10:40 AM   #11 (permalink)
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
Installed:
Kirill
Kirill is offline   Reply With Quote
Old 06-23-2007, 12:17 PM   #12 (permalink)
Date registered: Jan 2007
Vehicle: SLK 200 Kompressor (15Nov2000)
hy drilled only to front whelles? I not 4 discs?
I can't understand
slkpsm is offline   Reply With Quote
Old 06-23-2007, 12:22 PM   #13 (permalink)
Vehicle: 2002 SLK32 Silver Renntech pullies
Looks great!!! Do you feel any braking improvement after installation?
BTW, I can't find that would fit slk32.
jerryxu is offline   Reply With Quote
Old 06-23-2007, 01:44 PM   #14 (permalink)
Kirill's Avatar
I can't understand
Because Rears are fine for now. I needed new pads and rotors for front so I replaced with crossdrilled.
Old 06-23-2007, 01:53 PM   #15 (permalink)
Kirill's Avatar
I notices it takes somewhat longer like 1/50th of a second for initial bite when I start to use brakes at high speeds like 100MPH - may be I making it up and it's the same, or may be it's due to smaller initial contact area on porterfield pads - they have triangular shape - as they get worn contact area gets bigger - probably for initial burnin. No significant difference, but I was very happy with SLK brakes to start with - only went with drilled rotors for looks.
Interesting - even main brembo catalog doesn't list applications for SLK32 Breco Brake System - Aftermarket 2007
You probably can get drilled rotors from C32.
Old 06-24-2007, 05:47 AM   #16 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 1991 300CE, a work in progress.
why drilled only to front wheeles? I not 4 discs?
I can't understand
The rear brakes do not work anywhere near as hard as the front brakes do in stopping a car. The effort supplied by the front brakes can vary from 70% to 90% of the braking force while the rears only 30% to as little as 10%.
If you look at your brakes you will see the rear discs are MUCH smaller in diameter, have less brake surface, and use much smaller pads. Obviously the pistons are quite a bit smaller, but that may not be as easy to see.
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
Winston Churchill
"In my many years I have come to a conclusion that one useless man is a shame, two is a law firm and three or more is a congress."
John Adams
"If you carry a gun, people will call you paranoid. That's Ridiculous..If I have a gun, what in the hell do I have to be paranoid For."
Clint Smith, Director of Thunder Ranch
Bruce R. is offline   Reply With Quote
Old 06-24-2007, 04:30 PM   #17 (permalink)
damo320's Avatar
Date registered: Jun 2006
Vehicle: 01 SLK 320 auto
Do the drilled discs make any more noise than plain ones?? I had some EBC Turbo Groove discs on a previous car which made a noticable whirr sound every time i braked which can be off putting.
damo320 is offline   Reply With Quote
Old 06-24-2007, 04:47 PM   #18 (permalink)
Kirill's Avatar
None. Very quiet. But keep in mind - i got Brembo, results may vary with different brands.
Old 06-27-2007, 10:33 AM   #19 (permalink)
Kirill's Avatar
So - I locked the wheels today.
Was driving in traffic around 40MPH and was paying attention to a guy on a side and if he is going to try to squeeze in front of me - suddenly realized the Honda in front of me was slowing down. So i hit the brakes really hard and BAS kicked in. Wheels locked almost instantly - car followed the straight line, nothing dangerous. After I did let go of brake pedal - BAS still was applying brakes with about half of pressure for half a second. So I went 40MPH to about 5MPH in instant - brakes worked perfectly !
Guy in a wan behind me probably needs a new underwear.
Old 06-27-2007, 01:11 PM   #20 (permalink)
damo320's Avatar
I need to replace my discs soon because they are warped and quite worn (probably original after 90k miles) and was looking for Brembo ones. Anyone know where I can get them for a 320 in the UK??
Brembo Makes Cross Drilled Rotors for the ML? yes or no? siegeliv W163 M-Class 9 12-31-2005 08:58 PM
brembo slotted and cross drilled rotors with kevlar pads. nimit W163 M-Class 7 10-31-2004 03:29 PM
brembo cross drilled and textar (oem) pads installed wkeyau The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 05-17-2003 05:16 PM
Brembo Cross drilled rotors with Porterfield brake pads cabby850 W210 E-Class 0 01-07-2003 12:09 PM
Cross Drilled Rotors: Brembo contacted me Orion W208 CLK Class 0 09-26-2001 04:45 AM
