98 SLK 230 rear wing window - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 05-16-2007, 10:43 AM Thread Starter
Date registered: Jan 2007
Vehicle: 1998 SLK 230 Kompressor
Question 98 SLK 230 rear wing window
Does anyone know why my right rear wing window doesn't come up when I close the roof. Everything works fine except the wing window doesn't close. I can get it to close after playing with the top a couple of times or driving around and flipping the roof switch. It only does it sometimes????? Help what is causing this. Rookie SLK Owner.
jmorino is offline
post #2 of 15 (permalink) Old 05-16-2007, 12:12 PM
SLK RICK's Avatar
Date registered: Dec 2006
Vehicle: 2006 SLK 350
Quoted: 21 Post(s)
Check that the seals around the opening for that small window arent loose and somehow blocking it's movement. I had a similar experience after having to remove some of those seals and hardware. I didn't put them back exactly in place, and one of them was rubbing the window enough that it restricted the window from moving. After I went back and re-aligned everything. It worked fine.
Just watch the window carefully while someone holds your button for the top up, and top down operation, and you'll see if something's blocking it.
SLK RICK is offline
post #3 of 15 (permalink) Old 05-17-2007, 03:37 PM Thread Starter
I've tried that. The window just doesn't try to roll up at all. Then, a in a couple of try's it magically rolls up but, only after several try's. Someone mention safety switches???
jmorino is offline
post #4 of 15 (permalink) Old 06-21-2007, 05:42 PM
rasoul's Avatar
Date registered: Aug 2006
Vehicle: '03 SLK32 AMG
Send a message via AIM to rasoul Send a message via Yahoo to rasoul
hey, did you ever find a solution to this?
I was driving around today and my car started beeping at me and the roof light was flashing, although my roof was completely up. To make sure, I put it down then back up, and everything came up but the small fin windows. I can raise the roof and lower the roof but I can't get those small windows to roll up now. I hold the button and I can hear the whirring of the motor in the trunk, but it never completes the cycle. Maybe a faulty sensor or a wet PSE? I'll have to check on that when I get home, but until then it's parked in the garage because the incessant beep beep beep from the roof alert is driving me nuts!
rasoul is offline
post #5 of 15 (permalink) Old 06-21-2007, 08:06 PM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
I think on yearly years these windows were known to jump tracks
Kirill
Kirill is offline
post #6 of 15 (permalink) Old 06-21-2007, 11:27 PM
rasoul's Avatar
hmm well I guess that means I'm really hoping I just need to dry off the PSE because if it's something else I'm going to be really bummed out. It's just a pain in the ass to get to is all, because I did a battery relocation to the trunk and the new battery tray traps the PSE in. The motor just hums like it's trying and trying to pull the windows up with no luck. I'm starting to think something might have changed when I moved the battery.
rasoul is offline
post #7 of 15 (permalink) Old 06-22-2007, 10:12 AM
rasoul's Avatar
PSE is bone dry
Any ideas?
The roof sequence never stops, that little motor just keeps whirring and the red light stays on the whole time... little windows don't budge.
rasoul is offline
post #8 of 15 (permalink) Old 06-22-2007, 10:58 AM Thread Starter
No I didn't it only does it sometimes. Like when I store the car for a week or two. Drop the top and when I raise it the right rear window won't come up. If I drive the car and push the roof switch it will eventually come up. I sprayed some WD-40 on the tracks to see if that would help. Making sure that the window wasn't sticking. Keep trying is all I did.
jmorino is offline
post #9 of 15 (permalink) Old 06-22-2007, 04:44 PM
rasoul's Avatar
Anyone have a reference I can start troubleshooting with? perhaps a roof sensor diagram or anything like that? I've checked fuses and dried up everything in the trunk and am out of ideas.
Thanks
rasoul is offline
post #10 of 15 (permalink) Old 06-22-2007, 06:59 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
These 'may" help
Bazzle
Bazzle is offline
rear wing for trunk and back window redvelvetceo C208/A208 CLK-Class 1 03-21-2006 05:10 AM
Where can I purchase the SLK 55 REAR WING? slkfans R171 SLK-Class 20 03-20-2005 10:07 AM
for sale original lorinser rear window wing 220 chasis ///amg W220 S-Class 6 09-12-2004 10:22 AM
Lorinser Rear Window Wing/garnish CLK55///AMG C208/A208 CLK-Class 1 04-04-2004 01:14 AM
What do you guys think of putting the SLK32 wing on a SLK 230? Jason R170 SLK-Class 3 07-19-2001 06:17 PM
