Can you tell me if the projector part of the light can be removed from the unit or is it plastic welded in? can you post a picture of the back of the light with the rubber bungs removed ?
Found these RHD units. Cheaper in Pounds with exch rate.
I can post pic of the wires and the soldering in the connector if anyone likes. I will take pics of the "busy" lights tonight and post up.
I would appreciate pics of the solder connections for both the city lights (so I'll now exactly which wires in the connector to solder to) and where the angel eyes are soldered to the back of the city lights...I will try to wire it up the same way. If you can get the euro spec turn signal connector, let us know the part number. The way you have the lights wired now, if you do get the euro connectors won't the angel eyes only light up with the turn signals (which might be ok)?
The connector will have a part number on it (thats how we finally found the right pin for the headlight connector) IF one of our overseas friends can get us the number off theirs we can try to order some.
No the wires they are on now are for the "park lamp circuit" not the turning circuit. There are three wires in the connector 1 for turn, 1 for Park and 1 shared ground
On the drivers side its the grey/blk stripe for park/city lights and on passenger side its grey/red stripe
Here is how I wired the city lights to the angel eyes. This is the headlight that was missing the plugs I was talking about...a little annoying but not a deal breaker. I just used some silicon sealant and no problem. Not really a problem here in Southern Cali but if it rains alot you would get moisture in the lights.
And here it is ALL DONE. I think it looks real clean the way I did it.
Oh yeah.....I have not been feeling well this weekend and I forgot to mention.
About the park/turn signals. The US spec cars will have to use the original light bulb/holder. The EURO spec ones only have single filament bulbs (for turn only, that I want) and the connectors are different enough that I can't just re-wire them to fit.
