» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 04-09-2007, 07:33 PM   #11 (permalink)
yosefk's Avatar
Date registered: Feb 2005
Vehicle: '01 S500V, '98 SLK230K (sold), '04 Volvo S60R GT AWD
Send a message via MSN to yosefk
Originally Posted by Dano1234
Quite a few years ago I bought a BMW from B&L and had the same issues. For another option or possibly a second opinion, try Prestige Auto in Kitchener. The owner is Ayub and he specializes in MB's. He's fabulous and a bunch of friends are using him now too. I've attached a link. He worked for MB for many years and I have yet to see him stumped.
prestige auto loc: Kitchener, ON - Google Maps
Good luck!
Dan
That is awesome, I am definitely going to check that out. I've never fully trusted B&L but I prefer them over the dealership. I would prefer to do everything myself, but I just don't have all the tools and time that I wish I did.
Ayub and Prestige auto can hopefully shed some light on this situation. Thanks Dan!
Also noteworthy, I took a drive to North York and back today, and while my cruise control worked fine at 100km/h, it didn't hold at 130-140 for some reason. If i set it and released the pedal, the car would decelerate as if there was no cruise. But if I let go of the pedal and held the lever up, to accelerate, it eventually would hold the speed, but not very well... I found that to be really odd and I wonder if it's related... Hmmm.
2001 W220V S500 - Silver ext, black int.
Stock, and slick as ever.
SOLD- 1998 R170 SLK230 Kompressor:
Black ext, Red int.
2004 Volvo S60R GT AWD - Titanium ext, Atacama int.
yosefk is offline   Reply With Quote
Old 04-09-2007, 08:13 PM   #12 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Prob not. Cruise uses the speed sensors off the wheels. If there is a differnce in tyre diameter front to rear due to wear or pressure the error is greater the faster you go so it drops out.
Bazzle
Bazzle is offline   Reply With Quote
Old 04-09-2007, 08:26 PM   #13 (permalink)
yosefk's Avatar
Bazzle
Good call on that one Bazzle.. You're totally right. My tires are a couple cm larger in the back, they're 245/50 and my fronts are 225/50.
Old 04-09-2007, 09:55 PM   #14 (permalink)
Bazzle's Avatar
Tire size calculator
I wonder if this affects the trans computer in any way??
Bazzle
Old 04-09-2007, 10:32 PM   #15 (permalink)
yosefk's Avatar
Bazzle
I'm not sure, do you think it does?
Old 04-09-2007, 11:18 PM   #16 (permalink)
Bazzle's Avatar
Only way to be sure is to borrow some wheels and tyres of correct diameter.
Im wundering if the trans computer talks to the ABS comp and restricts its actions if errors found?
Bazzle
Old 04-09-2007, 11:48 PM   #17 (permalink)
yosefk's Avatar
well, I ran factory sized tires last year when this happened for the first time... as well as all winter. I have my factory rims with my winter tyres on them which I could mount, but I have a feeling it won't make a difference in my case...
Old 04-10-2007, 09:02 AM   #18 (permalink)
Vehicle: 1999 SLK 230
yosefk,wow what a tough break on the series of transmission failures.It's enough to make you consider a manual(well,almost).When you changeout to manual,IIRC,not only are there linkage changes but you have to get a clutch/pressure plate assembly(hydraulic activated?)and a thrust bearing as the crankshaft is now under loading from the clutch.
My auto trans(knock on wood)has only had the connector plug leak.Warranty covered the fairly simple fix.
Good luck,
ch7ckc
ch7ckc is offline   Reply With Quote
Transmission Troubles? Classic City W126 S,SE,SEC,SEL,SD,SDL Class 1 04-21-2006 09:49 PM
What to do with SLK with a failed transmission? SIlver_Lana R171 SLK Class 28 07-13-2005 01:04 PM
2003 C230 Compressor transmission troubles The Assassin General Mercedes-Benz 0 04-07-2005 11:08 AM
Transmission Troubles wsad W123 E,CE,D,CD,TD,TE Class 1 12-09-2002 10:52 AM
Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK Class 3 04-26-2002 11:05 AM
