Old 03-10-2007, 04:23 PM   #1 (permalink)
SP67's Avatar
Date registered: Apr 2005
Vehicle: 03 SLK 230
Brake Fluid Flush
I did my brake flush this weekend and here's how I did it. Thanks to everyone's post. I would have never been able to do it without the help from this site. I bought a brake bleeder from Autozone for $29 that was designed to be attached to the bleeder but decided not to use it (I would have attached the pics but I can only attach 10 files at a time). I just had the wife pump the brakes for me instead. I got the brake fluid from my dealer (Pic 1) for $19 (.75 liter and we used it all).
Step 1: I used a turkey baster to remove old brake fluid from master cylinder (Pic 2).
Step 2: Remove cap and filter from master cylinder (Pic 3).
Step 3: Remove old fluid (Pic 4). Fill to the max with new fluid.
Step 4: Jack up the car and remove tire. I started from the farthest to the closest tire from the master cylinder.
Step 5: Locate the bleeder and remove rubber cap (Pic 5 and 6 - rear, Pic 8 and 9 - front).
Step 6: With an adjustable wrench, loosen the bleeder until brake fluid starts to leak ( a couple of turns).
Step 7: Pump the brake pedal and collect old fluid (Pic 7 - rear, Pic 10 - front). Repeat until new fluid comes out. I couldn't tell with mine so we just pumped the brakes 10-20 times for the rear brakes (less for the front) just to be sure. Make sure to check the master cylinder often to make sure you have enough fluid (we checked and filled up every 10 pumps).
Step 8: With an adjustable wrench, tighten the bleeder and wipe any brake fluid excess.
Step 9: Cover the bleeder with the rubber cap.
Step 10: Put the tire back on.
SP67 is offline   Reply With Quote
Old 03-10-2007, 05:23 PM   #2 (permalink)
TheJimbo's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2001)
Nicely done man. Good write-up too. Have you noticed any change in brake performance as a result? I plan to do mine this Spring. I bought a power bleeder to do it.
2001 SLK230 Kompressor
2001 Dodge Dakota Quad Cab 4x4
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is online now   Reply With Quote
Old 03-10-2007, 08:22 PM   #3 (permalink)
SP67's Avatar
Vehicle: 03 SLK 230
Brake Fluid Flush
I didn't feel any difference but that's a good thing 'cause I was afraid I'd screw it up. I went for a drive around the block, tried to do slow breaking a few times then I slammed it hard once just to make sure I still have the power if and when I need it. Here's the pics of the bleeder I got from Autozone which I'll probably return. I also started to follow a DIY pressure bleeder that was posted here but that's when I saw the Autozone item. The parts for the DIY was easy enough to find at Ace Hardware, Home Depot and Autozone. Good luck with yours.
Old 03-10-2007, 09:55 PM   #4 (permalink)
Bazzle's Avatar
Vehicle: 1998 SLK230
Well done.
A couple of points.
Use a proper 6 or 12point spanner for the bleeder as they sieze up and may round off with an adj spanner.
If there is black crud in the bottom of master cyl try to get it out before bleeding as it can get washed down to the Caliper seals.
Bazzle
Added to Tech sticky above
Bazzle is offline   Reply With Quote
Old 03-11-2007, 06:50 AM   #5 (permalink)
TheJimbo's Avatar
This is the one I got (Power Bleeder Pro):
Products Bleeders
Can't wait to try it out this Spring. I'm going to swap the brake lines for braided stainless steel at the same time.
Old 03-11-2007, 09:03 AM   #6 (permalink)
papa's Avatar
Date registered: Jun 2006
Vehicle: SLK 320 BRABUS Modded
And remember to pump the brakes befor you drive it.
One of our fitters years ago backed off the ramp into the workshop wall, didnt pump the brakes first
papa is offline   Reply With Quote
Old 03-11-2007, 09:41 AM   #7 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240
SP67
Thanks for the pics, but I'm not too sure about something here. Did you mean to say 'repeat steps 4 - 10 for the other 3 wheels'?
Otherwise there's quite a lot of old fluid still in the system.
keyhole is offline   Reply With Quote
Old 03-11-2007, 08:44 PM   #8 (permalink)
SP67's Avatar
Vehicle: 03 SLK 230
Brake Fluid Flush
Keyhole,
Sorry, you're right. Repeat steps 4-6 for each tire. If you only bleed one line, the other three lines will still have the old fluid even though your master cylinder is full of new fluid. Good catch.
Old 03-13-2007, 12:34 PM   #9 (permalink)
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
another intresting product to help bleed brakes Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
Kirill
Kirill is offline   Reply With Quote
Old 03-14-2007, 01:42 PM   #10 (permalink)
16falcon's Avatar
Date registered: Oct 2004
Vehicle: 2002 SLK 32 AMG
Originally Posted by Kirill
Have you used these? They sound like a pretty elegant solution to bleeding the brakes.
16falcon is offline   Reply With Quote
To flush brake fluid now? DA_SURG R170 SLK Class 10 08-19-2005 05:42 PM
Coolant & Brake Fluid Flush - added B service items noelb W163 M-Class 5 09-17-2003 03:55 PM
Is a brake fluid flush & replacement supposed to be part of the B service?... Daniel W163 M-Class 7 03-20-2003 07:44 PM
Some more info on brake fluid and coolant flush. Darkmann W163 M-Class 1 03-17-2003 08:46 AM
Warranty work or not.: Brake fluid flush controversy. Darkmann W163 M-Class 10 03-17-2003 05:44 AM
