Old 02-24-2007, 08:31 AM   #1 (permalink)
ALephart's Avatar
Date registered: Dec 2006
Vehicle: 1998 SLK 230 KOMPRESSOR
Send a message via AIM to ALephart
LED reverse lights and plate lights installed
Wow what a difff. Some may say the LED reverse lights are brighter then stock, but thats wishful thinking. They are slightly dimmer but thats ok in my book.
The license plate lights are very nice though! Bright and crisp light. But along with that came the bulb out warning light on the dash. No big deal, i'd rather pull the bulb in the dash then revert my chages!
Aaron Lephart
smart car info www.smartcar451.com
SLK32 Front/rear calipers and rotors
Hawk EP + pads
ATE fluid
Stoptech lines
AMG 17'' sport rims with Toyo T1R's
ASP 10% overdrive pulley, Bosch FR5DC plugs, fuel pressure riser
LED interior lights.
KONI adjustable shocks
Ceramic coated exhaust manifold and valvecover.
NEW OEM black interior
Simpleroof
ScanguageII
Projector beam headlamps
4500K Xenon/HID headlight bulbs
Sprintbooster
CLK style grill
OEM SL antenna color matched
Dynamat
ALephart is offline   Reply With Quote
white LED lights for aftermarket LED mirrors deyainrdy4ds W208 CLK Class 1 02-18-2007 02:33 PM
New xenon lights to match the LED running lights plevine W208 CLK Class 0 09-06-2005 07:13 PM
Installed stereo, now reverse lights on in every gear? 2000ML320SUV W163 M-Class 1 09-17-2003 01:24 PM
Lights .. installed bi-xenon and fog lights WITH pictures BOTONOSI W163 M-Class 5 05-05-2003 08:03 PM
Anyone have any pictures on the LED brake lights, LED indicators would be better Import Tuner Typ R170 SLK Class 4 07-16-2002 09:39 PM
