Old 01-29-2007, 02:16 PM   #1 (permalink)
Date registered: Nov 2005
Vehicle: 99 slk230
Maf Cleaning?
CAn I use Brake CLeaner to clean my maf sensor? and what part of the MAF do i spray? the Thin Metal Wire?
peace and love!!!
Dolphin27 is offline   Reply With Quote
Old 01-29-2007, 02:34 PM   #2 (permalink)
lcdial's Avatar
Date registered: Jun 2006
Vehicle: 2001 SLK320 - Red, Magma Red
I used electrical contact cleaner. I read somewhere that brake cleaner is too harsh, but I could be wrong.
I sprayed pretty much the whole thing, but I focused on the metal wire. Good luck!
lcdial is offline   Reply With Quote
Old 01-29-2007, 03:09 PM   #3 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Yes it will work, spray thru the insert liberally and shake dry
Bazzle
Bazzle is offline   Reply With Quote
Old 01-30-2007, 05:10 AM   #4 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
Get some CRC Mass Airflow Sensor Cleaner
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 01-30-2007, 06:06 AM   #5 (permalink)
TheJimbo's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2001)
This is the best stuff, but in the event you don't find it, CRC also makes an electrical contact cleaner (spray as well) that works pretty good. Like Baz says, spray liberally and allow to air dry - don't touch the filaments with fingers or cloth!
This worked for me.
2001 SLK230 Kompressor
2001 Dodge Dakota Quad Cab 4x4
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is online now   Reply With Quote
Cleaning the MAF sensors..? Seems that we don't need to be buying MAF sensors all the time..? AC_ML W163 M-Class 11 01-30-2008 03:49 AM
MAF cleaning tips ReZzZ320 W210 E-Class 2 12-21-2006 10:22 AM
Cleaning MAF patsslk R170 SLK Class 7 10-04-2006 04:38 PM
V6 MAF cleaning - how far did you go ? Kirill R170 SLK Class 10 08-02-2005 08:03 PM
Cleaning the MAF Sensor... Icebergb28 W163 M-Class 1 10-29-2003 12:26 PM
