serpentine belt replacement - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 01-12-2007, 06:58 AM Thread Starter
Date registered: Dec 2006
Vehicle: 2000 slk230,firemist
Question serpentine belt replacement
ive searched the threads and found all kinds of great info, im really interested in bassles cool created tool, i know when to replace and generally how to release tension on idler, a real tutorial with pictures would be excellent. mine are little frayed but i dont want to try it till i ask the experts. thanx for all your consistently great advice and patience for the newbies.
ganndallff is offline
post #2 of 22 (permalink) Old 01-12-2007, 07:26 AM
page62's Avatar
Date registered: Aug 2003
Vehicle: 2001 SLK320, 2001 C320
No rocket science to this one...
Just take a socket wrench to the nut on the idler pulley. Pull on it to release the tension on the belt. Remove belt and replace. If the nut breaks loose, tighten it down and try again.
Current: 1989 300E
Past: 2001 SLK320, 2001 C320, 1979 450SL
page62 is offline
post #3 of 22 (permalink) Old 01-12-2007, 07:42 AM Thread Starter
im a pitiful rocket scientist, a/c power steering belt has inverted torx on pulley, looks like shock attached to pulley, supercharger belt has no bolt head, im probably looking at the wrong pulley, access from above or below, thanx for your help.
post #4 of 22 (permalink) Old 01-12-2007, 10:11 AM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
All access is from above.
Only the 2 idlers with torx on end need pulling to your left to release tension.
The nut will not come undone as it isnt a nut just a shaft to grab onto. Nut is seperate behind plastic flip off cover (for idler pulley removal.)
I used an 8mm 12 point ring spanner for torx with one end cut off and a bit of tube welded on for leverage.
A normal long bar on a socket will also work if profile is low enough.
Put tool on torx.
Push tool to your left standing looking at engine from front (rh sideof engine bay)
Being careful of tension and fingers slip belt off idler.
Release tension.
Remove belt
!! Pay attention to routing.!!
Replace belt.
Reapply tension and slip belt over idler pulley
Release tool
Check visually sitting on grooves correctly
Start engine and stop straight away and recheck seating.
Bazzle
ichris's_dad56 likes this.
Bazzle is offline
post #5 of 22 (permalink) Old 01-12-2007, 01:23 PM Thread Starter
once again, the light bulb goes on, thanx
post #6 of 22 (permalink) Old 01-12-2007, 03:13 PM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
Serpentine belt
This is the one
ID:	112240   Click image for larger version
ID:	112241   Click image for larger version
oberoi is offline
post #7 of 22 (permalink) Old 02-25-2008, 11:48 AM
cocktailsfirst's Avatar
Date registered: Sep 2005
Vehicle: 2008 CLK550 CAB
Changing my belts this past weekend but not having all the tools necessary to create the pulley tension tool I used a 9mm socket on a 1/4 inch wrench with a old spark plug socket slipped over the wrench handle and a 12 inch extension connected to that. There was plenty of leverage to move the tensioner. Thanks to oberoi for the pics and Bazzle for the easy idea.
2008 CLK550 cab
Santa Barbara, CA
cocktailsfirst is offline
post #8 of 22 (permalink) Old 04-11-2008, 10:06 PM
Date registered: Apr 2008
Vehicle: Black 2001 SLK 320 6spd
Help please
Hi
I used an 8mm (hex) socket to relieve the tension. Worked great to remove my old frayed belt. Didn't work so hot to put the new belt on. Ended up stripping the torx end. B4 I got the belt on. So now I'm beltless and not sure what to do.
Any suggestions will be greatly appreciated. Thanks in advance.
slkmike2001 is offline
post #9 of 22 (permalink) Old 04-12-2008, 12:43 AM
Bazzle's Avatar
Bazzle is offline
post #10 of 22 (permalink) Old 04-13-2008, 10:23 AM
Date registered: Jun 2006
Vehicle: 1998 slk230
my E10 is also in poor shape, so I just used a semi-deep socket and ratchet on the nut thats on same bolt. I think it may have been a 16mm.
Joe
Seattle
1998 slk230
koaea is offline
    "V Belt" as MB calls it or Serpentine Belt 98MBE320 W210 E-Class 12 01-05-2010 02:36 PM
    Serpentine Belt Replacement S600 vtyagi W140 S-Class 2 08-03-2005 03:33 PM
    '89 190E 2.6 serpentine belt replacement alas W201 190-Class 4 01-15-2005 07:16 AM
    Idle & Starting & Serpentine belt replacement on 2.3L ltooz W201 190-Class 0 09-22-2004 02:57 PM
    '98 E320 Serpentine Belt Replacement mharmes W210 E50 AMG, E55 AMG 0 01-16-2004 01:55 PM
