Old 01-06-2007, 04:54 PM   #1 (permalink)
Date registered: Aug 2005
Vehicle: 2001 SLK320, 1996 Harley Davidson Sportster 883
cleaned MAF, now rougher idle
I picked up the MAF cleaner today after it was ordered for me yesterday. Got home from work and took the MAF out and apart and sprayed it like the instructions on the can said. Put it all back together and closed the hood. When I started the car up right after that the car had a very rough idle, nearly rocking back and forth. Is that normal? I have it in the garage for the night, hopefully a good night rest will allow it to reset everything and when I use it tomorrow all is better. Tired of that idiot light coming on.
peckels01 is offline   Reply With Quote
Old 01-06-2007, 09:32 PM   #2 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Sounds like MAF cleaner got into comb chamber and made it miss. Did you go for a run yet?
Bazzle
Bazzle is offline   Reply With Quote
Old 01-07-2007, 06:27 PM   #3 (permalink)
whats the comb chamber? and where would it be. i didn't have time personally to drive it today as i had to get to work, but my father did and he said it was still sluggish. when i did start it today it was mega rough and when i backed it out of the driveway and put into drive it nearly cut off twice so i quickly pulled back into driveway and shut it off. had an awful smell as well. seemed as though fumes from the spray stuff had stayed behind or something. when i got home from work and turned it on it seemed ok, not rough. but didnt take it for a drive and the light was still on on the dash. guess i need to call the warranty company and see if they will cover the labor to have it looked at up at the stealership and get the parts needed replaced. grr.
Old 01-07-2007, 07:34 PM   #4 (permalink)
TheJimbo's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2001)
When you sprayed it with the MAF cleaner, did you allow it to sit and air dry before reinstalling it? Or did you put it back still wet?
2001 SLK230 Kompressor
2001 Dodge Dakota Quad Cab 4x4
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is offline   Reply With Quote
Old 01-07-2007, 08:00 PM   #5 (permalink)
i let it sit and dry, stuff dries on impact basically but i did let it set for a bit.
Cleaning the MAF sensors..? Seems that we don't need to be buying MAF sensors all the time..? AC_ML W163 M-Class 11 01-30-2008 04:49 AM
Cleaned my bundts... dbtk W123 E,CE,D,CD,TD,TE Class 3 05-14-2006 05:25 PM
No Kompressor after installing cleaned MAF :-( mitaci R170 SLK Class 8 04-26-2006 03:59 PM
Engine cleaned and... dsilvar W126 S,SE,SEC,SEL,SD,SDL Class 24 11-05-2005 07:19 AM
Has anyone ever cleaned their engine before? If so, what did you use? APD R170 SLK Class 9 12-12-2001 12:26 PM
