Old 12-20-2006, 12:24 AM   #1 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Spring and Pad removal - Front
Got me new spring comps in mail today Had to have a play.
http://cgi.ebay.com/ebaymotors/ws/eB...8576&rd=1&rd=1
Great to use, wonder why I didnt get them a years ago, $180 on Ebay plus $33 post to Oz. Got an oxygen (lambda) sensor socket too $12)
Use all safety precautions you need etc etc.
I had to take off my suit as very dusty work this
1. Loosen wheel bolts 17mm padded socket
2. Jack up under sill
3. Remove bolts and wheel
4. Put 2nd jack under lower arm to take tension off shock.
5. Remove lower shock bolt 16mm
6. Place a jack under opp sill to save having to remove sway bar (allows even droop)
7. Insert spring compressor plates
8. Fit and align centre shaft
9. Tighten centre bolt and check plates aligned correctly
10. Fully tighten until spring loose in seat as required.
11. Carefully remove spring and/or pad as required. (see the 4 pips, no4 pad)
12. Refit and Check top pad and bottom spring seat alignment in recesses.
13. Loosen centre bolt until comes loose and remove shaft.
14. Remove plates.
15. Refit shock lower bolt
16. Replace wheel.
17. Nip up wheel bolts in the air.
18. Spin wheel and check for bearing noise./ Check for bearing play
19. Remove opp side jack
20. Remove jack under lower control arm.
21. Lower main jack under sill
22. Retighten wheel bolts (check all 4 wheels)
23. Drive up driveway and back to settle and check all is ok.
24. This is how I check and adj camber.
Front 88.7 degrees (1.3 neg) Rear 89.3 degrees (.7 neg)
25. Lip to ground measurements 646mm front, 660mm rear
26,,, Bazzles Helper Ha Ha, Cazzle didnt see that coming
Bazzle
Bazzle is offline   Reply With Quote
Old 12-20-2006, 12:31 AM   #2 (permalink)
Bazzle's Avatar
cont
Old 12-20-2006, 12:34 AM   #3 (permalink)
Bazzle's Avatar
More
Old 12-20-2006, 01:09 AM   #4 (permalink)
brabus.slk's Avatar
Date registered: Feb 2006
Vehicle: 1999 230
GREAT WRITE UP! Bazzle, no doubt about ya m8, you don't mind having a go.
Your missus also did a great job with all the pics she took of you getting amongst it.
Your a LUCKY MAN!
brabus.slk is offline   Reply With Quote
Old 03-01-2007, 12:58 PM   #5 (permalink)
Vehicle: 2002 SLK32
Bazzle, I would have liked to see how you did in the rear springs. I found the rear much more difficult to do than the fronts. Even after disconnecting the shock in the rear, I found that the rear control arm is being help up by something which makes it difficut to compress the spring enough to remove it. It come loose but I can get it out. I've had to remove the bolts of the control arms beside the diff and drop the whole control arm to get the spring out. Do you know what is holding the wheel up even after loosing the shock?
SteveL is offline   Reply With Quote
Old 03-01-2007, 01:18 PM   #6 (permalink)
TheJimbo's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2001)
Jeez Baz, the work you do and taking the time to take pics and document the whole process.......amazing!
2001 SLK230 Kompressor
2001 Dodge Dakota Quad Cab 4x4
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is offline   Reply With Quote
Old 03-01-2007, 01:26 PM   #7 (permalink)
Bazzle's Avatar
Correct Inner mounting (camber) bolt and shock bolt needs popping out.
Use a trolley jack under just in case some tension left.
Bazzle
Old 03-01-2007, 02:42 PM   #8 (permalink)
Vehicle: 2002 SLK32
Originally Posted by Bazzle
Correct Inner mounting (camber) bolt and shock bolt needs popping out.Bazzle
Do you have a pic of where the Inner mounting bolts are? Just want to make sure we are talking about the same thing.
Old 03-01-2007, 09:08 PM   #9 (permalink)
OJwerks's Avatar
Date registered: Apr 2006
Vehicle: SLK..lower than yours
Send a message via AIM to OJwerks Send a message via MSN to OJwerks
so you lowered the front end a little ?
<a href="http://www.flickr.com/photos/27267135@N03/2654436453/" title="IMG_4552 by ojwerks, on Flickr"><img src="http://farm4.static.flickr.com/3070/2654436453_8085c8474f.jpg" width="500" height="375" alt="IMG_4552" /></a>
OJwerks is offline   Reply With Quote
Old 03-02-2007, 03:46 AM   #10 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
Well done, and with great photo's. How about a few less of the car, and a few more of Cazzle? ..............
2002 SLK 32,
1987 190E 2.3-16 valve
"A vote is like a rifle: its usefulness depends upon the character of the user."
Theodore Roosevelt
"In any survival situation, you should try to keep your friends alive as long as possible. They stay fresh longer that way.
Unknown
Bruce R. is online now   Reply With Quote
ML500 W164 front shock/spring removal? mitchmarket W164 M-Class 0 10-28-2006 06:23 AM
spring pad question neil_martinez W208 CLK Class 4 02-01-2006 03:39 PM
Front and Rear spring pad benzo4me W208 CLK Class 0 08-31-2005 06:33 PM
front spring removal gdbmj W123 E,CE,D,CD,TD,TE Class 1 07-15-2004 12:05 PM
Lowering: Spring Pad, AMG Spring, H&R, Cup Kit, Bilstein gab R170 SLK Class 2 11-24-2001 03:29 PM
