» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 05-30-2008, 12:28 PM   #21 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Originally Posted by isarescu View Post
Bazz how can i get that switch out? (the sw under the r/h side brush that tells the roof the boot lid is tilted back.) It`s locked in a metal frame and the visibility is`nt great and i can`t see what to push to realease. Thx!
Its held in with a square platic flap and a lipped flap into the metal plate. You have to pull it down and out. Mine broke one of the tags last week when I knocked it playing with the new tail lights. I just used silicone glue when I put it back.
Go to page one and look at pix...
Bazzle is offline   Reply With Quote
Old 06-23-2008, 11:01 AM   #22 (permalink)
Date registered: May 2008
Hi guys - I have the same problem and have checked the boot switch and it is running fine but the problem is still there.
How do I check the roof switches and the relay?
gnomenatty is offline   Reply With Quote
Old 06-23-2008, 02:54 PM   #23 (permalink)
kieran_sly's Avatar
Vehicle: 98 SLK 230K
The roof switches are pretty easy to check, you need to remove the roof lining first. This is done by opening the roof half way and undoing the 3 screws at the front and the 3 either side (In the plastic trim). You'll see the two switches at the front of the roof when the lining is removed.
Check that the microswitches spring open when allowed to.
Putting the roof lining back by yourself may prove a bit tricky so try and get someone else to hold it up while you screw it in! oo er.
kieran_sly is offline   Reply With Quote
Old 07-02-2008, 01:03 PM   #24 (permalink)
isarescu's Avatar
Date registered: Jan 2008
Vehicle: SLK 230 Kompressor, 2001
Originally Posted by kieran_sly View Post
Went to open the roof, the windows went down, the trunk opened and .......nothing, the roof wouldn't come down.
Same problem here. Even after I got the sw under the r/h side brush that tells the roof the boot lid is tilted back replaced.
isarescu is offline   Reply With Quote
Old 07-02-2008, 02:07 PM   #25 (permalink)
kieran_sly's Avatar
isarescu, have you checked the switch at top of windsceen (under sun visor) and the two at front of actual roof (Under roof lining). These are all easy to check and as I understand are all common causes of this syndrome.
Old 07-02-2008, 02:10 PM   #26 (permalink)
isarescu's Avatar
I have sercahed the forum and it seems that thouse sw are the problem. First thing tomorow i will order new ones.
Old 07-02-2008, 05:39 PM   #27 (permalink)
Bazzle's Avatar
This could go on forever.
Hope new ones fix your issues.
Easy to remove the bellows that causes them to stick 1st just to isolate the prob and/or use a jump lead to short the cables out to emulate the sw in question.
Old 07-03-2008, 01:27 AM   #28 (permalink)
isarescu's Avatar
Bellows=Mechanical contrivance for creating a jet of air, consisting usually of a hinged box with flexible sides, which expands to draw in air through an inward opening valve and contracts to expel the air through a nozzle. Invented in medieval Europe, the bellows was commonly used to speed combustion, as in a blacksmith's or ironworker's forge, or to operate reed or pipe organs.
Old 07-03-2008, 03:21 AM   #29 (permalink)
oztds's Avatar
Date registered: Oct 2006
Vehicle: Two 1998 SLK230s, 2003 SLK230 SE
...as used in the steam powered PSE in the back. Don'tforget to stoke coals into the exhaust. Also as used on accordions.
Bazzle was referring to the covering over the switches shaped like the concertina which expands and contracts.
“The difference between genius and idiocy? Genius has its limits." - TWS
oztds is offline   Reply With Quote
Old 07-03-2008, 10:10 AM   #30 (permalink)
Bazzle's Avatar
Some more info
Window Switch Repair ebrington W163 M-Class 11 07-13-2007 08:23 PM
Switch repair ??????- Climate Control MikeMc W140 S-Class 3 10-01-2006 11:15 AM
no power to roof switch +roll bar switch ELV R129 SL Class 0 07-03-2005 02:37 AM
Power Seat Switch Repair? E-Klasse R170 SLK Class 2 11-30-2004 08:13 PM
Roof Switch Wally C. R170 SLK Class 0 08-31-2001 04:30 PM
