» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 05-22-2008, 06:43 AM   #11 (permalink)
CMount's Avatar
Date registered: Jun 2007
Vehicle: 1998 Mercedes SLK 230 Kompressor
Originally Posted by Bazzle View Post
Time will tell if its the correct one will be 40 centigrade here on Sat
Bazzle
Wow it's only 12c here in Dublin at 1pm I guess global warming doesn't affect everywhere
CMount
CMount is offline   Reply With Quote
Old 05-22-2008, 10:05 PM   #12 (permalink)
oztds's Avatar
Date registered: Oct 2006
Vehicle: Two 1998 SLK230s, 2003 SLK230 SE
It should be the same as Aussie SLKs (ie. Bazzles's) are RHD and built to UK spec according to the sticker in the fusebox.
“Perseverance is more prevailing than violence; and many things which cannot be overcome when they are together yield themselves up when taken little by little." - Plutarch. "None are so hopelessly enslaved as those who falsely believe they are free." - Johann Wolfgang von Goethe
oztds is offline   Reply With Quote
Old 05-22-2008, 10:35 PM   #13 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Originally Posted by Cairnhill View Post
Bazzle, I opened that "Limit open" switch in the boot and it's contents differ from yours. My car is a 1997 230K. The actual switch-head of mine bears directly onto the plastic wedge operated by the stop-bar; also the construction & wiring of the terminals is different as well as the connection of the 2 wires. I enclose a picture .
yours is the same, doesnt matter what way around the 2 wires are.
Bazzle
Bazzle is offline   Reply With Quote
Old 05-22-2008, 10:38 PM   #14 (permalink)
Bazzle's Avatar
Originally Posted by kieran_sly View Post
I have only had my 98' SLK 230 for just under a week now, Went to put the roof up, the windows opened, the trunk opened... and then nothing, just a whirring sound.
I searched and found this thread, seemed just what I was looking for. So I set about locating the rear switch under the brush, problem was I cant find it?
Would it still be on the right hand side of the car as you look at it from the rear (Bearing in mind I have a UK model, RHD). How many and which panels should I have to remove? I can see the main hydraulic unit on the right beneath the cover if it helps.
As I am a noob please respond in easy to understand terms as I am not quite up on all the tech speak yet!!
PS loving the car so far, just need to get this prob sorted out for the great British Summer!
Thanks
See third pic, arm of boot lid contacts it when fully open for roof to drop in/out.
DANGER
NOTE: If you play arond in here with roof half open you MAY loose your fingers.
IF you must at least make sure engine is runningbso it doesnt suddenly drop on your hand.
Bazzle
Old 05-23-2008, 12:04 PM   #15 (permalink)
kieran_sly's Avatar
Date registered: May 2008
Vehicle: 98 SLK 230K
Thanks guys, So I found the switch, took it out and gave it a good clean and replaced it.
Went to open the roof, the windows went down, the trunk opened and .......nothing, the roof wouldn't come down. Does this still point to the same switch?
Thanks
A frustrated SLK owner
kieran_sly is offline   Reply With Quote
Old 05-23-2008, 03:00 PM   #16 (permalink)
Bazzle's Avatar
Thanks
Easy to prove, run 2 wires out from sw and join together as roof lifts.
Old 05-23-2008, 03:45 PM   #17 (permalink)
kieran_sly's Avatar
Thanks Bazzle, Thought there must be some way of testing it. Do you mean bridge the terminals of the input plug while the trunk is opening, i.e. leaving the switch out of the circut thus eliminating it?
Thanks
Old 05-23-2008, 04:03 PM   #18 (permalink)
Bazzle's Avatar
No, just join 2 wires across the 2 that go too the sw and short them out to see if fault goes away.
Old 05-27-2008, 09:58 PM   #19 (permalink)
DickB's Avatar
Date registered: Dec 2002
Vehicle: 1999 SLK 230
I did this last year on a road trip to get the roof to open when the switch failed. Impressed the heck out of my son (I had him short the wires at the proper time).
DickB is offline   Reply With Quote
Old 05-30-2008, 09:54 AM   #20 (permalink)
isarescu's Avatar
Date registered: Jan 2008
Vehicle: SLK 230 Kompressor, 2001
Bazz how can i get that switch out? (the sw under the r/h side brush that tells the roof the boot lid is tilted back.) It`s locked in a metal frame and the visibility is`nt great and i can`t see what to push to realease. Thx!
isarescu is offline   Reply With Quote
Window Switch Repair ebrington W163 M-Class 11 07-13-2007 09:23 PM
Switch repair ??????- Climate Control MikeMc W140 S-Class 3 10-01-2006 12:15 PM
no power to roof switch +roll bar switch ELV R129 SL Class 0 07-03-2005 03:37 AM
Power Seat Switch Repair? E-Klasse R170 SLK Class 2 11-30-2004 09:13 PM
Roof Switch Wally C. R170 SLK Class 0 08-31-2001 05:30 PM
