» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 03-26-2009, 06:06 AM   #71 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 1991 300CE, a work in progress.
Ignition tumbler
Thank Jeff Kushner for this:
http://www.benzworld.org/forums/r170...-you-cant.html
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
Winston Churchill
"In my many years I have come to a conclusion that one useless man is a shame, two is a law firm and three or more is a congress."
John Adams
"If you carry a gun, people will call you paranoid. That's Ridiculous..If I have a gun, what in the hell do I have to be paranoid For."
Clint Smith, Director of Thunder Ranch
Bruce R. is offline   Reply With Quote
Old 05-09-2009, 12:31 AM   #72 (permalink)
Date registered: Oct 2008
Question
Could anyone shed light on the proper link to "replacing the instrument Panel Bulbs" link lower on this page? Be ever so grateful!
Max
Originally Posted by manicdemise View Post
Thanks to Str8Pryd for your professional photoshopie skills:
Comprehensive Differential Fluid Exchange (PDF).
Comprehensive Transmission Fluid Exchange (PDF):
Example of everything you need for a transmission fluid change from AutoHausAZ:
QTY____Part#____________Product
6______ 001989210310____Lifetime Synthetic Transmission Fluid; 1 Liter Bottle (recommended)
1______ 1402700098______Transmission Filter Kit
1______ 2035400253______Transmission Gasket/Bushing/O-Ring; Adapter Plug with O-Rings
1______ 1409910055______Transmission Filler Tube; Lock Pin for Filler Cap; Red
1______ J2024-110887_____AT Dipstick
MB part# for the transmission dipstick is 140589152100. Also see PHOTO DIY- 722.6X TRANSMISSION FLUID CHANGE. Or try this other useful link: MercedesShopWiki: 722.6 Transmission Fluid and Filter Change
How-To... (gotta love 'em)
Reset FSS
Open the door, put the key on the ignition, close the door.
Move start switch into position "2"
Within the first 4 seconds after moving start switch into position "2", press the reset button for trip counter twice within one second.
The display for the service request is thus activated for 10 seconds
Within these 10 seconds move start switch into position "O". The service request continues to be displayed
Press reset button for trip counter and hold pressed
Continue to hold reset button for trip counter (about 10 seconds) until the signal sounds and the new start distance appears in the display.
Reset Throttle Body
Press the gas pedal to the floor... past the kick down point
Hold the pedal there for 15 seconds
After 15 seconds while foot still planted, turn the key off but do not remove it
Release gas pedal... Wait at least 2 minutes while not touching anything in the car, don't open the door even.
After the 2 minutes start the car and drive off normally...
Dyno Mode
The device will have a sticker on it saying ABS/ASR (here lies is the root of all evil). By Disabling (unplugging) the traction control (ESP/ASR/ETs/ABS) module located in engine bay, near the brake fluid reservoir you'll see a black/sliver unit with lots of small metal lines coming out of it; disconnect the fat connector on the front, push up and out: You will now have entered "Dyno Mode"--the old school way. When you start the car now you will get a few warning lights on the dash... car now has NO ABS or TRACTION CONTROL - PERIOD. After you plug it back in, it will register a fault in memory (CEL) which a hand held OBDII reader can erase. Be safe and use this tid bit of knowledge wisely, I mean, don't terrorize the streets in "Dyno Mode."
Online Resources
2000-2004 SLK 230/320 Operator's Manual PDF (19.8MB)
03'-09' MB brochures
Infamous 'How To' by David R. Leonoff
MB Part# w/EPC graphics
Replacing Head Gasket
Replacing Air Condition Dashboard Bulb
Replacing Intrument Panel Bulbs
Replacing Engine Mounts
Buellwinkle's C230 How-To
Buellwinkle's Resources
SLK Star Tech (Buellwinkle's Detailed How-To's)
SLK Parts List PDF (Buellwinkle's)
Parts Suppliers:
AutoHausAZ*
Parts Train*
eBay Motors
MB SuperStore
Used Parts
More Used Parts
maxcichon is offline   Reply With Quote
Old 05-09-2009, 01:57 AM   #73 (permalink)
Date registered: Oct 2007
SLK Home Page
livefreeordie is offline   Reply With Quote
Old 06-14-2009, 04:25 PM   #74 (permalink)
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 Bahama Blue/Quartz Sand 97,XXX Miles
Service & recall bulletins http://www.startekinfo.com/StarTek/ then click on "Star Bulletins"
StarTuned magazine archives https://www.mbwholesaleparts.com/Sta...p/archives.jsp
leapyfish is online now   Reply With Quote
Old 07-01-2009, 12:04 AM   #75 (permalink)
leapyfish's Avatar
R170 Option Codes
Codes of all the options for R170 models.
Old 07-08-2009, 12:36 PM   #76 (permalink)
leapyfish's Avatar
Radio code finder
If you don't have the security code for your radio try here Код магнитолы Radio Code - Мерседес клуб (Форум мерседес)
yes its in russian
Old 07-14-2009, 07:02 AM   #77 (permalink)
Chris64's Avatar
Date registered: Jun 2009
Vehicle: 1997 SLK 230
Crossfire/Mercedes SLK230
Originally Posted by Bazzle View Post
All the old Tech Tips, look here too
http://www.benzworld.org/forums/r170...rs-repost.html
New ones also added below: for example MBSLK.de
Translated version of http://mbslk.com/index.php
Translated version of http://mbslk.com/modules.php?name=News&new_topic=3
Oxygen Sensor replacement -slk230
http://www.benzworld.org/forums/r170...placement.html
Supercharger Bearings
http://www.benzworld.org/forums/r170...-number-3.html
Glove box manual
Mercedes SLK Class Owners Manual and more | Analog Stereo
Cross fire Tech manual (slk R170 + V6)
http://www.rasoul.com/upload/2005_Cr...ice_Manual.pdf
Crossfire SRT6 Documentation Collection
* Need Interior paint? alan@viponds.com.au
SLK 320 Airfilter change
Alternator regulator changeover (slk230, 320 similar)
http://www.benzworld.org/forums/r170...nt-slk230.html
Auto gear lever rattle
Auto Trans selector
Reverse light switch
http://www.benzworld.org/forums/r170...up-lights.html
Wheel and tyre fitment
Mercedes AMG BMW new used & refurbished alloy wheels & tyres, UK wheel alloys
Auto oil change
http://www.benzworld.org/forums/r170...-exchange.html
PSE
http://www.benzworld.org/forums/r170...fit-check.html
read thru the next few pages and see if you can find what you want. Dont forget the OLD tips in 1st link above
Seat repair
http://www.benzworld.org/forums/r170...over-swap.html
Bazzle
Is that right that the SLK engine is the same as the Crossfire. I have been trying to find a workshop manual for my SLK, and came across this. I have downloaded the pages, and looking at it, it seems to be exactly the same as my SLK
Chris64 is offline   Reply With Quote
Old 08-09-2009, 02:35 PM   #78 (permalink)
leapyfish's Avatar
Lubing Vario roof
Thanks to oberoi http://www.benzworld.org/forums/r170...-1-krytox.html
Old 08-15-2009, 11:57 AM   #79 (permalink)
Date registered: Mar 2009
Rebuilding Convertible Top hydraulic cylinders
http://www.benzworld.org/forums/r170...cylinders.html
Jmarkoa is offline   Reply With Quote
Old 09-28-2009, 09:11 AM   #80 (permalink)
Bruce R.'s Avatar
Hydraulic cylinder overhaul with photo's, thanks to wilsophia :
http://www.benzworld.org/forums/r170...full-pics.html
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
NEWBIES and OLDIES check here: FYI's ,Tech tips, DIY's, Buyer's Guide, etc. coachgeo Unimog 17 09-15-2006 07:43 PM
Tech Tips in Houston H-TOWN230 R170 SLK Class 7 11-03-2005 09:22 AM
Tech question about stock and RB tech exhaust Babushka W210 E-Class 4 04-04-2005 09:53 PM
Ok, my rusted tips is gone Neww SS tips installled JimB W163 M-Class 18 05-04-2003 09:16 PM
