» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 08-20-2008, 03:34 PM   #62 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 1991 300CE, a work in progress.
Possible rear view mirror replacements..... Thanks Kirill...
http://www.benzworld.org/forums/r170...nt-mirror.html
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
Winston Churchill
"In my many years I have come to a conclusion that one useless man is a shame, two is a law firm and three or more is a congress."
John Adams
"If you carry a gun, people will call you paranoid. That's Ridiculous..If I have a gun, what in the hell do I have to be paranoid For."
Clint Smith, Director of Thunder Ranch
Bruce R. is offline   Reply With Quote
Old 08-21-2008, 06:48 PM   #63 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Roof hydraulic cylinder replacemen
http://www.benzworld.org/forums/r170...hydraulic.html
http://www.benzworld.org/forums/r170...r-removal.html
Bazzle is offline   Reply With Quote
Old 11-09-2008, 06:09 AM   #64 (permalink)
Bruce R.'s Avatar
Pictorial DIY: Replacing Lateral Movement(Acceleration) Sensor
http://www.benzworld.org/forums/r170...eleration.html
Old 12-05-2008, 11:14 AM   #65 (permalink)
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 Bahama Blue/Quartz Sand 97,XXX Miles
SLK instruction manuals
http://safemanuals.com/brand-user-gu.../MERCEDES-BENZ
http://www.mbusa.com/mercedes/#/servPrtsOwnersManuals/
leapyfish is offline   Reply With Quote
Old 02-08-2009, 06:43 AM   #66 (permalink)
Date registered: Sep 2008
Vehicle: '99 SLK230 sport
Post More Tips.....
Thanks to Str8Pryd for your professional photoshopie skills:
Comprehensive Differential Fluid Exchange (PDF).
Comprehensive Transmission Fluid Exchange (PDF):
Example of everything you need for a transmission fluid change from AutoHausAZ:
QTY____Part#____________Product
6______ 001989210310____Lifetime Synthetic Transmission Fluid; 1 Liter Bottle (recommended)
1______ 1402700098______Transmission Filter Kit
1______ 2035400253______Transmission Gasket/Bushing/O-Ring; Adapter Plug with O-Rings
1______ 1409910055______Transmission Filler Tube; Lock Pin for Filler Cap; Red
1______ J2024-110887_____AT Dipstick
MB part# for the transmission dipstick is 140589152100. Also see PHOTO DIY- 722.6X TRANSMISSION FLUID CHANGE. Or try this other useful link: MercedesShopWiki: 722.6 Transmission Fluid and Filter Change
How-To... (gotta love 'em)
Reset FSS
Open the door, put the key on the ignition, close the door.
Move start switch into position "2"
Within the first 4 seconds after moving start switch into position "2", press the reset button for trip counter twice within one second.
The display for the service request is thus activated for 10 seconds
Within these 10 seconds move start switch into position "O". The service request continues to be displayed
Press reset button for trip counter and hold pressed
Continue to hold reset button for trip counter (about 10 seconds) until the signal sounds and the new start distance appears in the display.
Reset Throttle Body
Press the gas pedal to the floor... past the kick down point
Hold the pedal there for 15 seconds
After 15 seconds while foot still planted, turn the key off but do not remove it
Release gas pedal... Wait at least 2 minutes while not touching anything in the car, don't open the door even.
After the 2 minutes start the car and drive off normally...
Dyno Mode
The device will have a sticker on it saying ABS/ASR (here lies is the root of all evil). By Disabling (unplugging) the traction control (ESP/ASR/ETs/ABS) module located in engine bay, near the brake fluid reservoir you'll see a black/sliver unit with lots of small metal lines coming out of it; disconnect the fat connector on the front, push up and out: You will now have entered "Dyno Mode"--the old school way. When you start the car now you will get a few warning lights on the dash... car now has NO ABS or TRACTION CONTROL - PERIOD. After you plug it back in, it will register a fault in memory (CEL) which a hand held OBDII reader can erase. Be safe and use this tid bit of knowledge wisely, I mean, don't terrorize the streets in "Dyno Mode."
Online Resources
SLK Star Tech
2000-2004 SLK 230/320 Operator's Manual PDF (19.8MB)
03'-09' MB brochures
Infamous 'How To' by David R. Leonoff
MB Part# w/EPC graphics
Replacing Head Gasket
Buellwinkle's C230 How-To
Buellwinkle's Resources
SLK Parts List PDF (Buellwinkle's)
*Replacing Air Condition Dashboard Bulb
*Replacing Intrument Panel Bulbs
*Replacing Engine Mounts
*www . mercedesshop . com/...
Parts Suppliers:
AutoHausAZ
Parts Train
eBay Motors
MB SuperStore
Used Parts
ManicD3MEY3Z
manicdemise is offline   Reply With Quote
Old 02-22-2009, 12:26 PM   #67 (permalink)
Date registered: Jan 2007
it wants you to copy a verification code.....but doesn't give you one!! has anyone got this site to work?
chopstick1 is offline   Reply With Quote
Old 02-22-2009, 08:15 PM   #68 (permalink)
leapyfish's Avatar
yes I have,
click on "List of the top manuals MERCEDES-BENZ (user manual, user guide, operating instructions, instructions for use & instruction manual)"
enter "slk" in the search window and press return
click on your model
click on "Download the complete user guide "
it will then give you the code and you can download it
not simple, but its free
Old 02-22-2009, 08:53 PM   #69 (permalink)
32krazy!'s Avatar
Date registered: Oct 2008
Vehicle: PROUD OWNER! 2002 slk32 AMG
it asks to copy a 4 digit code but no code is given
32krazy! is online now   Reply With Quote
Old 02-28-2009, 06:42 AM   #70 (permalink)
Bruce R.'s Avatar
Side window adjustments, thanks to Kobus:
http://www.benzworld.org/forums/r170...ind-noise.html
NEWBIES and OLDIES check here: FYI's ,Tech tips, DIY's, Buyer's Guide, etc. coachgeo Unimog 17 09-15-2006 07:43 PM
Tech Tips in Houston H-TOWN230 R170 SLK Class 7 11-03-2005 09:22 AM
Tech question about stock and RB tech exhaust Babushka W210 E-Class 4 04-04-2005 09:53 PM
Ok, my rusted tips is gone Neww SS tips installled JimB W163 M-Class 18 05-04-2003 09:16 PM
