» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 03-17-2007, 10:51 PM   #21 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Transmission connector leak fix
http://www.benzworld.org/forums/show...=1#post2287316
Good info on how to remove and part number ref:
Bazzle
Bazzle is offline   Reply With Quote
Old 03-24-2007, 03:08 PM   #22 (permalink)
Bazzle's Avatar
Hands free kit install
Mercedes-Benz R170 SLK hands free car kit install
Bazzle
Old 03-25-2007, 01:41 PM   #23 (permalink)
Bazzle's Avatar
Maf removal V6
Slk 320 (V6) Maf removal and clean
Picasa Web Albums - Lance - SLK MAF Cleaning
Thanks to Icdial
Bazzle
Old 04-08-2007, 12:56 PM   #24 (permalink)
Bazzle's Avatar
Brake light sw BAS light
http://www.benzworld.org/forums/show...=1#post2320284
Bazzle
Old 04-09-2007, 10:59 PM   #25 (permalink)
Bazzle's Avatar
Mercedes shop DIY
MercedesShopWiki: MercedesShop - Do It Yourself
Bazzle
Old 04-15-2007, 02:05 PM   #26 (permalink)
Bazzle's Avatar
Window limit stop and adjustment
http://www.benzworld.org/forums/r170...djustment.html
Bazzle
Old 04-27-2007, 05:25 AM   #27 (permalink)
Bazzle's Avatar
Vario Roof Main cylinder removal
http://www.benzworld.org/forums/r170...r-removal.html
Bazzle
Old 06-01-2007, 01:31 PM   #28 (permalink)
page62's Avatar
Date registered: Aug 2003
Vehicle: 2001 SLK320, 2001 C320
Aftermarket head unit install
http://www.benzworld.org/forums/r170...unit-swap.html
<a href="http://www.wunderground.com/US/TX/San_Antonio.html?bannertypeclick=miniWeather2">
<img src="http://banners.wunderground.com/weathersticker/miniWeather2_both_cond/language/www/US/TX/San_Antonio.gif" border=0
</a>
page62 is offline   Reply With Quote
Old 06-08-2007, 03:31 PM   #29 (permalink)
Date registered: Nov 2005
Vehicle: 01 SLK200k
2001 SLK200K; oil & filter change is easy even without the suck thing. There's a conventional-enough drain plug in the sump, reached by dropping the plastic undertray beneath the motor. it's more convenient to use the suck thing, I suppose, but it's even more convenient to just let the dealer do it - however, DIY is a snap.
I needed 10mm socket to drop the undertray, and I used a conventional socket for drain plug - yes, it's a hex-head - or could use a spanner.
I needed a specific tool to pull the oil filter; GSF have the monster socket type. It's easy enough to do; note which way the old filter element comes out - mine wasn't the same at both ends, so be sure to install the replacement the same way round as the old one.
My engine let about 4L of oil out; I replaced it with 4L of 5w50 Mobil 1 and have the level midway between low and high marks on the dipstick at this time, having added no more.
Engine intake air and cabin vent air filters are also an easy change, plus you get the chance to clear all the old vegetation &c out of those areas.
So far, the only special tool needed was the special filter socket - about £10 at GSF. Other methods may work; I can't speak about those.
A plug change, or at least inspection, is a bit more esoteric because DCX don't use hex-head bolts to retain the coils. There's one per cylinder and they live above the plug; my 2.0 engine had male-form torx-head screws, needing torx E8 socket to allow me to pull coils off. After that, a long slim plug socket was necessary, but that's commonplace for any 4v engine.
So, in summary; the oil, filter and plug service was a breeze! The local dealer wanted about £250; they always have very polite people, smartly dressed, working in comfortable, clean, serene surroundings, and it's easy to see how.
regards to all
forker is offline   Reply With Quote
Old 06-12-2007, 02:03 PM   #30 (permalink)
Bazzle's Avatar
Serpentine belt replacement
http://www.benzworld.org/forums/r170...ighlight=belts
Bazzle
NEWBIES and OLDIES check here: FYI's ,Tech tips, DIY's, Buyer's Guide, etc. coachgeo Unimog 17 09-15-2006 07:43 PM
Tech Tips in Houston H-TOWN230 R170 SLK Class 7 11-03-2005 09:22 AM
Tech question about stock and RB tech exhaust Babushka W210 E-Class 4 04-04-2005 09:53 PM
Ok, my rusted tips is gone Neww SS tips installled JimB W163 M-Class 18 05-04-2003 09:16 PM
