Old 10-27-2006, 02:34 PM   #1 (permalink)
page62's Avatar
Date registered: Aug 2003
Vehicle: 2001 SLK320, 2001 C320
Headlight Install -- IMPORTANT information!
I just compeled my headlight install. It took a while, because it was a somewhat complex affair. Plan on a day when you have nothing else planned (except for beer, of course ).
First, inspect the new headlights to see how they are mounted. The parking light unit slides out in a very ingenious way!
On the car, slide out the parking light assembly to reveal a mounting bolt. Undo this bolt and the 2 screws that hold the headlight assembly in place. It's a bit tricky, but you'll figure out how to do it. Inspect the mounting bolt assembly below the parking light for a few moments to figure out how it works. I found I had to turn the black plastic bolt CLOCKWISE a few turns to remove, and COUNTERCLOCKWISE to tighten after installation.
You may also need to remove the grille mounting screws to get everything out...I ended up breaking off the tabs on the grille, but that's another story.
The parking light bulb & socket on the new lights ARE NOT CORRECT for North America. They use a 168 single filament bulb and connector, but the North American lamps use a 2357 dual filament bulb. Fortunately, the socket from the original parking lights fits in the new socket. Use it instead.
I have the factory xenon HID headlights, but I replaced them with halogens. In this situation, the wiring for the headlight leveling servo is not used...just tie it out of the way.
After I got everything installed, I discovered the high beams did not work. It turned out the be the included relay wiring harness for high/low beams. As it was wired, the relay DOES NOT WORK. I don't see how it could possibly work the way it was configured. I figured out how the change the wires in the base of the relay connector so it would work. If others have low beams only after installation, I will post re-wiring instructions.
Finally, note that the hood may be a little hard to close until the rubber grommet settles in a bit. Make sure it latches completely when closing.
That's about it. They look great and work great. It was just a bit challenging here and there along the way!
<a href="http://www.wunderground.com/US/TX/San_Antonio.html?bannertypeclick=miniWeather2">
<img src="http://banners.wunderground.com/weathersticker/miniWeather2_both_cond/language/www/US/TX/San_Antonio.gif" border=0
</a>
page62 is offline   Reply With Quote
Old 10-28-2006, 03:44 PM   #2 (permalink)
page62's Avatar
ttt
Old 10-28-2006, 05:02 PM   #3 (permalink)
krupple's Avatar
Date registered: Feb 2006
Vehicle: 1999 SLK230 Sport
Send a message via AIM to krupple
I was mistaken, I'm trying to take mine out right now and it's becoming a yotch.
krupple is offline   Reply With Quote
Old 10-28-2006, 05:45 PM   #4 (permalink)
page62's Avatar
Originally Posted by krupple
I think I'm missing something.
Perhaps you did...
Old 10-29-2006, 05:10 PM   #5 (permalink)
page62's Avatar
UPDATE: At first, I was not thrilled with the lighting pattern, but now I am. What had happened was that one of the adjusting mechanisms had come loose on each side -- the sideways adjuster on the left and the vertical adjuster on the right. Probably the UPS truck shook them loose. I spent some time fiddling and getting them hooked up. I now have full adjustment.
Conclusion: The lighting pattern is very European with a sharp cutoff. I am using GE Nighthawk 9003 bulbs. The lighting pattern is excellent (IMHO) and the bulbs are highly recommended. In fact, I prefer the lighting of these over the stock HID units. So save your money and buy the halogen kit. You can always upgrade to HID later, but properly aimed halogens work very well in this case.
Old 10-30-2006, 12:00 AM   #6 (permalink)
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 05 C230WK-05 E320CDi
I am really tempted to buy the halogen fixture and gut it. The clear lens finally opens the door to retrofitting a real set of projector beam bi-xenons. I know several who have done this already with Honda's so I only really need to get the bucks set aside to buy all the parts and then find the time to do it.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline   Reply With Quote
Old 10-30-2006, 07:13 AM   #7 (permalink)
Date registered: Aug 2005
Vehicle: 2001 SLK320, 1996 Harley Davidson Sportster 883
I thought this was supposed to be a plug and play type install as far as the wiring goes. I sure do hope when I install mine the high beam works. Thats why I ordered them because I was under the impression it would. I may be hitting you up for the re-wiring guide for this!
peckels01 is offline   Reply With Quote
Old 10-30-2006, 10:20 AM   #8 (permalink)
page62's Avatar
If it doesn't work, just let me know. It merely involves changing the way the wires are put into the relay socket plug. No big deal...once I figured it out!
Old 10-30-2006, 10:39 AM   #9 (permalink)
Date registered: Aug 2006
Vehicle: 01' SLK320
Thanks for posting up, I really don't know anything about the Halogen install due to mine being HID's, I'm sure that information will come in handy to a few. I didn't even think about putting the blinkers after putting the headlights on the car, I'm sure that would have made things easier
rvancil is offline   Reply With Quote
Old 10-31-2006, 07:28 PM   #10 (permalink)
so did anyone else order the chrome turn signal bulbs? the ones in the unit already are the orange and have one contact on the back. the chrome ones have two contacts on the back. the box for them says they are used for stop and taillight (1157) the ones for the blinkers should be the (PY21W) with the one contact on the back. next, the parking light feature, are there supposed to be bulbs for these? it didnt come with them. last, did anyone order the interior lights, if so where do they go? they look strange. thanks for the help. actually, i dont think i even got the interior lights i ordered, the ones i though were them seem to be the parking lights(LED?) help!!! want to be sure i have the right parts before i install so i can email the people we got these from if i got jipped at all.
Very important information regarding your food!!!!!! asianml Off-Topic 26 10-10-2005 12:48 AM
Very important information regarding your food!!!!!! asianml W163 M-Class 1 10-03-2005 03:52 PM
Headlight lens moisture seal information TXmudman R170 SLK Class 2 05-24-2005 08:37 PM
Important information for W463 owners Ufuk G-Class 11 01-16-2002 08:20 PM
IMPORTANT INFORMATION FOR EUROPA G500 OWNERS pete abrams G-Class 19 05-28-2001 06:11 AM
