How to replace headlight bulb - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-10-2006, 10:20 AM Thread Starter
Date registered: Apr 2003
The passenger side headlight of my 2001 SL 320 is gone, and I need to replace it.
I have a replacement bulb that I got from the dealer a few years ago, but don't know how to replace it.
Could you explain how to do it?
msmmgr is offline
post #2 of 5 (permalink) Old 10-10-2006, 12:28 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Is the SL the same as the SLK??
If so on rear of light unit is a black plastic cover.
Squeeze tap at bottom and rotate cover up and off.
Remove plug connector on globe.
Slip spring off globe base.
Reverse.
DO NOT allow fingers to touch glass on globe. Clean with metho if you do.
Bazzle
Bazzle is offline
post #3 of 5 (permalink) Old 10-11-2006, 06:24 AM Thread Starter
Thanks a lot, Bazzle.
msmmgr is offline
post #4 of 5 (permalink) Old 11-28-2010, 03:10 PM
eleaner's Avatar
Date registered: May 2008
Vehicle: 1995 320SL
Send a message via AIM to eleaner Send a message via MSN to eleaner Send a message via Yahoo to eleaner
Post 320 SL Front Passenger Headlight replacement
1. Drain some of the fluid in the reservoir or else some could spill in the next step.
2. Remove single nut and washer that mounts reservoir to frame.
3. Wiggle/lift reservoir out of way.
4. Squeeze two tabs at top of light bulb cover. It may not pop off but gently inserting a flathead screwdriver will separate it at the top.
5. Replace bulb.
6. Replace everything.
eleaner is offline
post #5 of 5 (permalink) Old 11-29-2010, 01:13 AM
Date registered: Jun 2010
Vehicle: SLK 230K sport, 99', Silver, 60K miles
Very easy to do. Borrowed my dads manual to do mine on the weekend. A little bit tricky to get to though and temperatures of -5C don't help!
Captainrave is offline
how to replace bulb in headlight switch mr diesel W123 E,CE,D,CD,TD,TE Class 2 09-12-2006 08:26 PM
NEW USER > HOW TO REPLACE THE BULB in DRIVER SIDE FRONT HEADLIGHT?? yak W220 S-Class 0 03-21-2006 08:22 AM
How to replace high- beam bulb in Bi-X Kretia W203 C-Class 5 01-14-2006 09:11 PM
anyone know how to replace fog light bulb? WhyTry! CLK 55 C208/A208 CLK-Class 3 06-24-2005 08:01 PM
replace license plate bulb? tomtomtomtom C208/A208 CLK-Class 2 05-03-2005 02:33 PM
