Need a knob for my AC/Heater Fan Control - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 09-13-2006, 07:24 PM Thread Starter
charris's Avatar
Date registered: May 2004
Vehicle: 2004 SLK Special Ed
Unhappy Need a knob for my AC/Heater Fan Control
Had an intermittent light, pulled the knob off and the plastic part that reaches inside to control the fan speed broke. If anyone has a spare and want to get rid of it PM me. I'll go to the dealer if needed, but thought I would check here first.
charris is offline
post #2 of 14 (permalink) Old 09-14-2006, 07:06 PM
mbfrakes's Avatar
Date registered: Jun 2006
Vehicle: '01 SLK320
Any pointers on removing the knob? I have a bad bulb that I would like to replace.
mbfrakes is offline
post #3 of 14 (permalink) Old 09-15-2006, 12:50 AM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
Smile Removing heater knob
Just checked my W202 manual which looks to have identical setup
to get to globes - looks like the front panel comes off first and then control panel is pulled out complete - no mention of knobs being pulled off ( or needing to)
Looks like globes would slip in the back
I can post or email the page if you havent got it figured out
Oberoi
oberoi is offline
post #4 of 14 (permalink) Old 09-15-2006, 05:07 AM
mbfrakes's Avatar
Vehicle: '01 SLK320
A post or email would be great. I was hoping it was as easy as removing a knob, but figured it was more like you describe.
mbfrakes is offline
post #5 of 14 (permalink) Old 09-15-2006, 05:17 AM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Pull knob off
Early models have globe open to you, use a bit of plastic tube to remove, later ones a have a plastic shield in front that must be carefully moved to one side to expose globe.
I have a spare knob here in OZ
Bazzle
ID:	98521   Click image for larger version
ID:	98522   Click image for larger version
Bazzle is offline
post #6 of 14 (permalink) Old 09-15-2006, 04:26 PM
oberoi's Avatar
Quoted: 33 Post(s)
Bazzle's nailed it! - the W202 book doesn't mention this.
Oberoi
oberoi is offline
post #7 of 14 (permalink) Old 09-15-2006, 04:55 PM
mbfrakes's Avatar
Vehicle: '01 SLK320
Bazzle, thanks. Pulled the knob off. The pictures were great. Just have to find some plastic tubing to get the globe out now.
mbfrakes is offline
post #8 of 14 (permalink) Old 09-16-2006, 12:17 AM
SlacKeR's Avatar
Vehicle: SL55 AMG (R230), ML 320CDI (W164)
Send a message via Skype™ to SlacKeR
Had same problem
I got mine from a dealer when it happened to me cost a few pounds $3-$4 I would guess. Even a dealer has limits to how much they can cane your wallet.
Aston Martin DB9
ML 320CDI 2005 (W164) - Cubanite Silver
Mini JCW 2004 - Blue
SL55 AMG 2003 - Jasper Blue
SlacKeR is offline
post #9 of 14 (permalink) Old 09-16-2006, 08:03 AM
Date registered: Sep 2006
Vehicle: 1998 SLK 230
You might want to try sticking small pieces of rubber to tips of needle noise pliers, I found it worked best as the bulb/globe gets too tight for the tube to pull-out. Just don’t crush to hard or you can break the bulb/globe, I did on one but was able to pull on the filament to get it out. ...... A little white grease on the gear/cogs and spring loaded pawl in the knob makes the operation feel much smother!!!
Don Reid is offline
post #10 of 14 (permalink) Old 09-16-2006, 08:06 AM
Don Reid is offline
    Heater Blower Fan afroney123 W123 E,CE,D,CD,TD,TE Class 8 02-08-2010 06:30 PM
    fan heater modual??? Dolphin27 R170 SLK-Class 1 03-03-2006 06:25 AM
    Interior fan speed control knob Mooney W202 C-Class 0 09-21-2005 04:15 AM
    Loss of AC and Heater Fan Control Fiat8 W124 E,CE,D,TD Class 9 06-24-2005 02:59 PM
    126 HVAC Fan not working / Heater Fan Removal cam69ss W126 S,SE,SEC,SEL,SD,SDL Class 1 01-25-2005 11:31 AM
