Hi Deb,
Most of the feedback in the early days (when I was sending out the paint from home) was from women - I think they took a lot of trouble and were particularly appreciative of fixing up an otherwise perfect car.
To answer your questions - Spray is a different formulation(has to be thinner) and is suitable if you are pulling the panels out - I worry about overspray in the car.
The Viponds paint is a brushable type and is sufficiently 'flat' to work perfectly when wiped on with a lint free cloth.
I've just retouched my dash and console after 2.5 yrs and only needed to retouch parts with a cloth (not the whole lot)
I use a fine brush to build up chipped paint to the thickness of the original -wait to dry then a final wipe over with paint on a cloth.
This stuff dries fairly quickly so important to wipe on reasonably fast and not to go over any previous bits or you'll rub it off.
Here's the info I sent out earlier - let me know if you need any other inf.
Bruce
>>>>>> There are 2 beige colours and 2 different reds so get your exact
>>>>>> colour by putting your VIN into
Mercedes-Benz Club Russia | Mercedes-Benz / VIN
>>>>>> Contact Viponds on
info@viponds.com.au or Viponds Paints -
Viponds Paints - The Paint Colour Specialists - Architectural, Industrial Signwriting Industries and they will send 200mls to your door (USA) for
>>>>>> about $45 USD (they accept paypal in USD) - less for Australia
>>>>>> Ask for 'Tautflex Benz paint' + colour (quote paint code no.)
>>>>>> Consignment tracking is provided and paint is shipped in airline
>>>>>> approved containers
>>>>>> The paint dries to a very thin film and is pretty "matt" (non gloss)
>>>>>> and covers a multitude of sins. Even so, I became obsessive about
>>>>>> it and would not put up with anything less than 'as new'.
>>>>>> The really important thing is to feather off any loose edges with
>>>>>> wet/dry paper(wet) and be scrupulously clean with the prep
>>>>>> (I have a feeling that some of the original problems might have been
>>>>>> someone in the factory being a bit slack with prep before painting
>>>>>> - some people have had less trouble than others)- finish prep
>>>>>> with alcohol (methylated spirits or Prepsol type product)
>>>>>> No removal of panels necessary,
>>>>>> Very unusual to have damage on the edges and margins - if so just
>>>>>> touch these up first.
>>>>>> 90 min to do the whole lot (except the speedo bit which is probably
>>>>>> OK- paint this panel when you have to remove it to replace bulbs.)
>>>>>> Rough mask where carpet joins console and the air vents/dash top etc
>>>>>> do the cleaning with detergent first and then alcohol -- touch up any
>>>>>> chips until the thickness of the chip is up to the level of the
>>>>>> original paint - when dry, wipe the whole thing over with paint on a
>>>>>> lint free cloth.
>>>>>> Practice on the little panel under steering wheel is a good idea.
>>>>>> (one screw removal)
>>>>>> Start with under dash and dash- the push seat fwd and do rear of
>>>>>> console - - push seat back and do the front.
>>>>>> Good idea to unscrew console lid to wipe paint over separately.
>>>>>> (good practice piece)
