Originally Posted by punkrock I read through the post and have e-mailed Viponds to get the order. Does the new paint chip as easily as the old? Which is better to strip or not to strip. I'm talking about the car interior paint of course. |
The paint is the same as Benz use so is similarly 'chippable' but easily fixed.
If you are anything like me, you learn to be pretty careful with your interior after the first fix
If you just have the chipping on the top surfaces/under handbrake and ign. stripping is not necessary. You can get to all of the console by moving the seat.
use wet and dry paper (600 grit or finer) and wet rub the edges of the peeled bits - then clean with prepsol /detergent - wash off and finally wipe down with alcohol/methylated spirits -- do not touch any further
touch up peeled bits with small brush a couple of times and then wipe the whole console or at least the top surfaces with paint on a lint free cloth - it will look like new
Clean prep is the secret to keeping it on - I don't think the orig Benz prep was too good
