whining noise - HELP! - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 08-11-2006, 04:28 PM Thread Starter
Date registered: Sep 2005
Vehicle: 1999 SLK 230 Kompressor Sport
Question whining noise - HELP!
Hello all,
My SLK sat for about 3 weeks while I was in Europe. I got back exactly one week ago and started my baby with this strange grinding sound!? Ok... the grinding sound did not appear again and according to this forum it's kinda normal if car sits for a while...
BUT....
Yesterday I noted the whining sound, most audible around 40 mph, getting pronounced both during acceleration and slowdown. It sounds like a mosquito and its location is hard to pinpoint. It's either left front of the engine or left rear of the car.
So today I popped the hood and noticed a lot of cold water condensation around this cilinder shape (with a hose running toward the upper red engine cover) part located over the left front wheel compartment!??? Is this related? Yes it did rain this morning but the rest of the engine compartment was dry!?
Please help! Is this noise pointing out to a major failiure? I can't hear it while idling or at higher speeds? Your input is very much appreciated!
drbranko is offline
post #2 of 16 (permalink) Old 08-11-2006, 06:03 PM
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Sometimes if you get rid of your wife the whining stops. Is it gear noise? Try putting it in neutral and coast and see if it goes away, if it does then it's likely coming from the rear end. Check for leaks. I test drove a 99 SLK when I was shopping and it had a big rear end leak and it made noises that told me to avoid this car.
http://www.mylavista.com
Buellwinkle is offline
post #3 of 16 (permalink) Old 08-11-2006, 09:01 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Well
Whineing noise under acc and decel,
1. Supercharger
2. Idler bearing
3. Aircon pump
4. Vacumn leak
5. Water pump
6. Drive belt
7. Pinion bearing
8. heat shield touching
Please have anothe rlisten with window open...
Bazzle
Bazzle is offline
post #4 of 16 (permalink) Old 08-12-2006, 10:06 AM
DesignoSLK's Avatar
Date registered: Jun 2006
Vehicle: '00 SLK230 Designo Copper
DesignoSLK is offline
post #5 of 16 (permalink) Old 08-12-2006, 03:24 PM Thread Starter
Question please look at this
Ok guys... appreciate your humor... but this is not funny at all...
The noise is still present best around 40 mph including coasting in neutral (manual 5 speed) bot accelerating and slowing down. It appears that the noise cannot be heard below 40 mph or above 45 mph....
It is most likely comming from the front left area of the engine.
Popped the hood again and there is lots of cool water condensation at the same place....
Obviously I have to stop by my dealership, but I would still like to be informed about what's going on. Any idea on the possible problem and/or what is this going to cost me?
Here's the photo:
drbranko is offline
post #6 of 16 (permalink) Old 08-12-2006, 03:33 PM
Bazzle's Avatar
That looks like the aircon modulator. Condensation is normal as the gas inside is cold and the air outside has moisture in it.
Have you tried with aircon off the check that as a source?
It really is hard to diagnose noise over the net, sorry.
Bazzle
Bazzle is offline
post #7 of 16 (permalink) Old 08-12-2006, 03:38 PM Thread Starter
Hi Bazz!
Appreciate your comment as always....
So you are saying that the water condensation in this area is normal...
Ok, I will try driving with air on and off (EC button on) ... stay tuned...
drbranko is offline
post #8 of 16 (permalink) Old 08-12-2006, 03:40 PM
Bazzle's Avatar
Bazzle is offline
post #9 of 16 (permalink) Old 08-13-2006, 11:22 AM Thread Starter
Ok, I test drove my SLK again trying AC on and off. The whining sound can be heard both with AC on and off. However it appears that the car has to warm up before the noise appears. During first few minutes I could not hear anything around 40-45 mph.
Any ideas???
drbranko is offline
post #10 of 16 (permalink) Old 08-14-2006, 06:35 PM Thread Starter
And so it goes on.... today driving from work I lowered my windows... and oh boy... I could hear it more clearly as it was louder... could be comming from the rear end but I'm not 100% sure. What makes it a mistery is why it appears between 40-45 mph?
drbranko is offline
    A whining noise................. C-Rod W163 M-Class 20 07-06-2009 08:17 PM
    Whining noise under the dash? wae96 W201 190-Class 15 08-23-2007 12:02 PM
    Whining Noise Under hood.. way2fast4u W202 C-Class 1 07-15-2006 11:02 AM
    Whining noise with acceleration...... deeclo03 W163 M-Class 1 02-05-2006 06:01 AM
    Whining noise from engine. . . . . Joe W163 M-Class 3 02-19-2002 12:23 PM
