SLK 230 running rough when cold - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-10-2006, 04:45 PM Thread Starter
Date registered: Mar 2006
Question SLK 230 running rough when cold
My 2002 SLK230 has been difficult to start and doesn't run well for the first few minutes. I had the B service done less than 1000 miles ago just before it went out of warranty. Any ideas what is causing this???
lsarg27 is offline
post #2 of 11 (permalink) Old 06-10-2006, 06:07 PM
linh
Guest
Posts: n/a
Quoted: Post(s)
It normal on the slk 230.
post #3 of 11 (permalink) Old 06-12-2006, 08:43 PM Thread Starter
I dont really buy that because it didn't do it before the B service. Last night I had to crank it foralmost a minute before it would start.
lsarg27 is offline
post #4 of 11 (permalink) Old 06-13-2006, 03:24 AM
Date registered: Oct 2005
Vehicle: 1999 SLK230 2009 E350
Quoted: 2 Post(s)
Do you have a manual or auto transmission? The auto takes a bit longer to settle down than the manual. I have a manual and rarely have any kind of roughness at cold start. Occasionally it will stumble for 3 or 5 seconds and when it does, gentle pressure on the gas peddle helps. The only time I had a more severe roughness was traced to a tank of gasoline. Since then I only buy from gas stations that are on main roads and turn over the 93 octane quickly. B service is basically an oil change and inspection. Check under the hood to see if hose, etc. loose.
What is the milage on the vehicle? Spark plugs are a possible culprit.
upstate engineer is offline
post #5 of 11 (permalink) Old 06-13-2006, 03:53 PM
MidLife Crisis's Avatar
Date registered: Apr 2006
Vehicle: 04' SLK230 Komp.
Mine is noisy at the first minute of cold start
My 2004 SLK 230 SE Komp. does the same thing. It has a very "rough" sound when you first start-up. As I let it "warm-up", after about a minute it idles VERY nice. To me it almost sounds like a diesel when it first starts.
With the other MB that I owned (C230), it had none of the attributes of the SLK.
Drive fast,...take chances.
MidLife Crisis is offline
post #6 of 11 (permalink) Old 06-13-2006, 04:43 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Bazzle is offline
post #7 of 11 (permalink) Old 02-06-2007, 09:51 AM
lushansilva's Avatar
Date registered: Sep 2003
Vehicle: 1985 500SEL, 2006 S500 AMG Sport, 2009 SL550 AMG Sport
same for me this morning. it was 9deg. Fahrenheit. it sounded like a diesel....clackity clack clack! (though i love diesel) also when i put it in reverse, i feel a vibration. i wonder if that the sign of coil packs going bad. I'm going to test it his weekend. does anyone know the proper procedure for testing the coil packs? i also have an appointment scheduled with the local dealership to do the first transmission service. I'm wondering if that has to do anything.....
Lushan
1985 Blue Diamond 500SEL (W126)286,000mi, [FONT=Verdana][SIZE=2] K&N Filter, Euro Headlamp Conversion
1998 Brilliant Silver SLK230 Kompressor (R170) 210,000mi (RIP)
2004 Blue Steel E320 4MATIC (W211), 111k mi. (SOLD)
2006 Alabaster White S350 (W220) 186K mi (RIP)
2006 Brilliant Silver S500 Sport (W220) 65K
2009 Steel Grey SL550R Sport (R230) 60K
lushansilva is offline
post #8 of 11 (permalink) Old 02-06-2007, 03:59 PM
Date registered: Dec 2006
Vehicle: 2000 slk230,firemist
mine idles a little rough for about 1 or 2 minutes on startup, im thinking check valve feeds supercharger air to heat up cat converter and o2 sensors for emissions passage, runs great after that, so who cares, let it warm up and enjoy!
ganndallff is offline
post #9 of 11 (permalink) Old 02-06-2007, 04:45 PM
Date registered: Jan 2007
Vehicle: SLK 200 Kompressor (15Nov2000)
Yes my slk acts like that. normaly i only drive it at weekend, so many days stoped at garage. Normaly on startup it is a little rough, and sometimes i can identify some diferent noise, like gaz pression, maybe from fuel pump... normaly before engine startup..it is normal?
slkpsm is offline
post #10 of 11 (permalink) Old 02-06-2007, 05:52 PM
berk's Avatar
Vehicle: 99 slk230 sport
heres the weird thing, on mine 99 slk 230 stick, it will barely start and run rough as hell if i drive it daily. if i let it sit for 1-10 weeks without any running, it will start and purr like a kitten right off the trigger. this doesnt make any sense but it has become a pattern as i go through phases of daily driving and hardly ever driving it.
berk is offline
