» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 05-26-2006, 10:31 AM   #1 (permalink)
loO4la
Date registered: Aug 2005
Vehicle: limited ed. slk230
Question measuring rim size? limited ed. rim size??
this may seem like a silly question...but when measuring rims...you measure from one side of the rim to the other...basically the diameter, right????
i'm just double-checking b/c my slk230 is a limited edition & these special slks are supposed to come w/ limited edition 17" rims, right? i never thought to check its actual measurements until i recently bought new amg replicas for my car.
turns out...the ones i have are 18" rather than 17"...hmmm...
loO4la is offline   Reply With Quote
Old 05-26-2006, 10:39 AM   #2 (permalink)
irvingst
irvingst's Avatar
Date registered: Nov 2004
Vehicle: 2002 SLK32 AMG
No R170 SLK's came standard with 18" rims so you must be measuring them wrong. Why don't you look at what the tire says.
irvingst is offline   Reply With Quote
Old 05-26-2006, 10:46 AM   #3 (permalink)
loO4la
just from looking at them, they look like 17"...
but exactly how do you measure them w/o looking at the tire?
i'm thinking the previous owner might've swapped the originals for other ones?
Old 05-26-2006, 11:05 AM   #4 (permalink)
BrisK230
Date registered: Mar 2006
Vehicle: 2000 SLK230 Limited
Send a message via AIM to BrisK230
Yea those are the limited edition wheels, same ones i have on mine. They are 17s
BrisK230 is offline   Reply With Quote
Old 05-26-2006, 11:05 AM   #5 (permalink)
irvingst
irvingst's Avatar
Those are the 17" EVO wheels that only came on the 2000 SLK Limited Edition. I'm not a wheel expert, but obviously your measurement isn't the correct way to do it.
Old 05-26-2006, 11:09 AM   #6 (permalink)
430
Date registered: Oct 2002
Vehicle: SLK32, ML430
My guess is that you are including the lip in your measurement. The lip holds the tire in place but is not counted in the rim measurement.
430 is offline   Reply With Quote
Old 05-26-2006, 12:21 PM   #7 (permalink)
loO4la
your response helped out a lot...that's all i wanted to know...was how to measure...from where to where...thanks!
i just went in to discount tire to have my new 19" wheels installed & they told me the exact same thing...
Old 05-26-2006, 12:23 PM   #8 (permalink)
BrisK230
I don't mean to thread jack or anything, but to the enthusiast what would these wheels be worth. I know that the limited edition differences are basically worthless as MB didn't charge for them, but I'm just curious.
Old 05-26-2006, 12:56 PM   #9 (permalink)
irvingst
irvingst's Avatar
Not sure what there worth, but they are a very nice wheel. They also look great on the C Class. I have a friend that that had them on an older E class...not sure if it was a different offset...2 body styles ago...they really made the look of the car.
Old 05-26-2006, 01:15 PM   #10 (permalink)
Bruce R.
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
If I can put in my two cents..............
Pretty much you can't measure the rim from the outside. The tire size ( 15",16", 17", or 18") is the inside diameter if the tire itself. The rim, because of the shape, can be VERY hard to measure when there is a tire on it. Of course if a tire is on the rim, you can read the size off of the sidewall.....
The rim size is the diameter of the wheel where the inside of the tire bead sits.
2002 SLK 32,
1987 190E 2.3-16 valve
"If God didnt want us to eat animals.....why did he make them out of meat?"
Unknown
"Pacifism is a shifty doctrine under which a man accepts the benefits of the social group without being willing to pay; and claims a halo for his dishonesty."
-Robert A. Heinlein
Bruce R. is offline   Reply With Quote
