K40 relay circuit and associated - Mercedes-Benz Forum
post #1 of 109 (permalink) Old 05-17-2006, 02:27 PM Thread Starter
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
The famous K40 and surrounding components. Inc Fuel Pump relay and fuse inc in K40 as far as I can make out
Location in main component box next to battery.
http://www.classic-roadster.de/cgi-b...T=ITEM&START=K
Bazzle
ID:	85304   Click image for larger version
Bazzle is offline
post #2 of 109 (permalink) Old 05-17-2006, 06:38 PM
barndogz's Avatar
Date registered: Feb 2005
Vehicle: 2000 slk230 Komp
you're the best!!!!!!!!!!!!!!!
thankx
<br>for those who believe; no explanation is necessary.
for those who do not: none will suffice!<br><br><img src="http://www.dizpins.com/board/cheshirebounce.gif">
barndogz is offline
post #3 of 109 (permalink) Old 10-05-2006, 01:37 PM
TurboZo's Avatar
Date registered: Feb 2006
Vehicle: '00 SLK230 Sport
Man, you guys rock!!! Thanks for all the great posts!! I followed threads for my engine light codes...came across this one on the k40. here is what i found...
ID:	100667   Click image for larger version
ID:	100668   Click image for larger version
Yes, I know the kompressor is a supercharger and not a turbo...
TurboZo is offline
post #4 of 109 (permalink) Old 10-05-2006, 01:39 PM
TurboZo's Avatar
I'm going to re-solder the burnt out sections. Hope this fixes my issues.
Thanks again!! If it wasn't for this forum, I would have never come to this conclusion.
Thank Allah for this forum!!
Thanks guys!
-Zo
TurboZo is offline
post #5 of 109 (permalink) Old 10-05-2006, 06:17 PM
Vehicle: 2002 SLK 32 AMG 1997 SLK230 & 1978 280CE
Zo........excellent pics
It would be interesting to know what part of the circuit is burning out these
solder joints.... probably near impossible to determine unless you are an electronics engineer
I wonder if these are the same joints others have had to resolder
This thread now deserves a 5 star rating
Good luck with the fix.......please be sure to give feedback if it fixes your issues
David
David in Australia is offline
post #6 of 109 (permalink) Old 10-05-2006, 09:25 PM
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Deserves to be a sticky for sure.
http://www.mylavista.com
Buellwinkle is offline
post #7 of 109 (permalink) Old 10-05-2006, 09:38 PM
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Quoted: 30 Post(s)
David
Do you think it could be part of the Tip Start Circuit?
slk230red is offline
post #8 of 109 (permalink) Old 02-21-2007, 11:55 AM
TurboZo's Avatar
i never replied back to this post.
The fix worked and I haven't had a problem since then. Hope this helps others as well.
TurboZo is offline
post #9 of 109 (permalink) Old 02-22-2007, 10:27 AM
slk230280's Avatar
Date registered: Apr 2006
Vehicle: 2002 slk230
From the looks of the PCB board, something is generating too much heat.
slk230280 is offline
post #10 of 109 (permalink) Old 02-22-2007, 11:54 AM Thread Starter
Bazzle's Avatar
Its the current flow to the fuel pump. The orig soldered joints probably cracked (not an uncommon occurance) and the joint resistance increases. This is then a progression of heat, oxidisation etc until the soldered joint fails.
Bazle
Bazzle is offline
  • Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
