» Site Navigation
» Other Sites
Old 10-01-2005, 08:28 AM   #1 (permalink)
Date registered: Oct 2005
SLK 32 AMG power loss
I have a 4 yr old 32, 35k miles. Just developed a fault that Merc cant fix. At about 4500 rpm or under very heavy acceleration the kompressor cuts out (leaving me in very bad situations!). Merc put in on the computer and found a B28 fault - inlet pressure too high and changed the sensor. Has made no difference. They don't know what to do now. Anyone any ideas as I don't fancy paying for Merc's leaning curve. Tim.
timslk is offline   Reply With Quote
Old 10-01-2005, 09:48 AM   #2 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
RE: SLK 32 AMG power loss
If the dealer doesn't know what's wrong, ask to have the Zone Rep. look at the car. The Zone Reps. cover all the dealers in your area and see a lot more strange things then any given dealer. They also are in contact with the other Zone Reps. that cover the rest of the country. What can take a mechanic hours to find is usually found by a Zone Rep. in minutes....
2002 SLK 32,
1987 190E 2.3-16 valve
"A vote is like a rifle: its usefulness depends upon the character of the user."
Theodore Roosevelt
"In any survival situation, you should try to keep your friends alive as long as possible. They stay fresh longer that way.
Unknown
Bruce R. is offline   Reply With Quote
Old 10-03-2005, 12:47 PM   #3 (permalink)
Vehicle: E46 M3 Cab, MKV GTI, NCP91 Yaris
Sounds like a faulty intercooler or intercooler water pump. The intake temps gets too high and disengages the supercharger, but oddly enough it doesn't get registered in the ecu. If you have access to a OBD2 scanner, plug it in and see what the intake air temperature is (IAT).
Check the fuse for the intercooler water pump. It could be simple as that.
Got Drift?
rage2 is offline   Reply With Quote
Old 01-02-2006, 02:22 PM   #4 (permalink)
Hi there
I have recently posted a very similar problem and am working to resolve it.
Did you ever resolve your problem? What was it?
yorkey is offline   Reply With Quote
Old 01-03-2006, 09:08 AM   #5 (permalink)
tungster's Avatar
Date registered: Jun 2005
Vehicle: C2D SLK32K
Send a message via AIM to tungster
Read my reply to this same problem on this link.
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1241057&posts=15&fid=26
C2D 2002 SLK32K
C2Design and Kleemann Modified
360.0 hp 349.8 tq at the wheels
www..kleemann.dk
www.c2dusa.com
Mercedes Benz motto:
Das Beste oder Nichts!!
Translation "The Best or Nothing"
Current Mods:
Kleemann ECU/Pulley kit
Kleemann LSD (One of a Kind in USA for R170)
Kleemann High Performance Camshafts
Koni Shocks and Eibach springs
LSD Doors/Lambo Style Doors (www.lsd-doors.de)
Brembo GT Brakes
SL55 Y-Pipe
SL Grille
Quad Exhaust with 4 AMG Tips
New 18" ASA Wheels and Pilot Sport 2 Tires
Tire Pressure Sensors with LED readout in cabin
Euro front bumper (No Orange Side Reflectors)
Rear Tails lights smoked out
Bipes Vario Roof Commander
Valentine One Hardwired
K40 Laser Diffuser Front/Rear integrated into Rear View Mirror
tungster is offline   Reply With Quote
Old 01-21-2006, 04:15 PM   #6 (permalink)
Robbie's Avatar
Date registered: Jan 2003
Vehicle: 2003 230 Previous 200 & AMG 32,
Had same intermittent problem on my old 02 slk 32 AMG, limiter cut in suddenly above 4,500 revs as a saftey measure and I lost power, had to book it in twice to Mercedes of Gatwick, they puzzled over it before telling me it was a faulty valve of some sort, went fine after that.
Robbie is offline   Reply With Quote
Old 05-14-2008, 07:02 AM   #7 (permalink)
Date registered: Apr 2008
SLK 32 AMG power loss - Finally FIXED!
Hello Everyone! Finally, after months of searching for a fix to my similar problem (at 100Km +, the supercharger would not work, intermittantly), the problem was found! The Aux watercooler on the supercharger was not working, so when it heated up, the supercharger would automatically shut down. The code that was found was P2027, indicating that the intake temp was too high. The dealership had already check the codes several time, but had not seen this one. If you ask your repair person to check this particular thing, they will be able to diagnose it more quickly. Now that the repair has been completed, I have my rocket car back! The actually part name is Coolant Pump, and the part number in Canada is 500-03-86. Thanks to this forum, I was able to point the dealer in the right direction. Good Luck!
lorivo is offline   Reply With Quote
Old 05-14-2008, 09:01 AM   #8 (permalink)
430
Date registered: Oct 2002
Vehicle: SLK32, ML430
One of the issues with the IC pump going out is that it throws a warning not a "hard" code or a CEL. This makes it very difficult for most dealerships to identify the problem.
The IC pump from a Ford Lightning is the same pump we use and can be had for ~$80 vs. the ~$600 for the MB one.
Or you can "upgrade" your pump and run something more reliable like a Johnson Pump.
430 is offline   Reply With Quote
Old 05-14-2008, 09:12 AM   #9 (permalink)
Bruce R.'s Avatar
Details of which are in the Tech Tips and such sticky............
Old 05-15-2008, 03:07 PM   #10 (permalink)
Johnson Pump LOL!
