Old 09-09-2006, 01:52 PM   #71 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Parts listings MB
http://www.detali.ru/cat/oem_mb0.asp?TP=1
Bazzle
Bazzle is offline   Reply With Quote
Old 11-01-2006, 11:05 PM   #72 (permalink)
Bazzle's Avatar
Wheel alignment specifications
Standard SLK Alignment should be about--------------
Camber.....
Front: -1.22 +/- .33 degrees
Rear: -1.5 +/- .5 degrees
Toe in .....
Front: 2.28mm +/- 1.14mm total
Rear: 3.78mm +/- .8mm total
Caster......
Front: 5.2 degrees +/- .5 (.5 diff max between sides)
Suspension height.........measured from wheel centre to lip of guard
Front: 350mm standard /325mm minumum
Rear: 370mm standard / 340mm minimum
Standard SLK all models.
Bazzle
Old 11-01-2006, 11:33 PM   #73 (permalink)
Bazzle's Avatar
Roof Hydraulic cylinder repair
http://www.benzworld.org/forums/r170...lic-leaks.html
Old 11-03-2006, 07:50 PM   #74 (permalink)
Bazzle's Avatar
K40 Relay - Right hand drive
LHD opposite
Remove neg batt term
Remove computer lid
Unclip holding tang and lift up module
Pull off connectors
Open case of module
Inspect soldered joints for cracks, overheating, dry joint etc
An eyeglass may help (top left hand group of three)
Remove old solder and resolder with new
Replace module
Push on connectors
Remove and replace 40A fuse to wipe the contacts.
Replacelid
Replace neg batt terminal.
Start car
Redo radio code if required.
more: http://www.benzworld.org/forums/r170...ssociated.html
Bazzle
Old 11-09-2006, 10:48 AM   #75 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
This might be a repost, but I just found this:
http://www.kotikone.fi/eerola/auto/MBSLK230Kdiy.html
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 01-19-2007, 02:56 PM   #76 (permalink)
butterb97's Avatar
Date registered: Feb 2005
Vehicle: 97 E420 Sport
In regards to code P0500: If all the wheel speed sensors have been changed and my car is still in limp mode and I'm still getting this code, what should be my next step?
butterb97 is offline   Reply With Quote
Old 08-16-2007, 10:38 AM   #77 (permalink)
Real8's Avatar
Date registered: Oct 2006
Very good rundown and pics on the K40 Bazzle. In a former post I queried as to why you referenced the fuse panel being on the wrong side. DUH I forgot you all drive on the other side of the road down there. This car is much fun to drive, has a minor quirk or 2, but nothing major. Wife will not ride a Harley and the price is about the same. I thank everyone for the posts that keep it on the road extremely helpful stuff. Thx Bazz you da man. '99 SLK 230
Real8 is offline   Reply With Quote
