» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 09-09-2005, 05:54 AM   #11 (permalink)
430
Date registered: Oct 2002
Vehicle: SLK32, ML430
RE: Bad vibrations in reverse... any ideas?
pterion - 9/8/2005 10:31 AM
Just an update incase anyone was interested.
The dealer found two problems, one was in fact the motor mounts (which were completely trashed, all of the oil sprayed out of them) and the second was a leaking rear differential (honestly, I am not sure what that exactly indicates...).
Total cost was 1500$, my extended warrentee is only covering 650$ (the motor mounts are a wear and tear item).
PT
motor mounts are considered a wear item? That is pretty much BS in my book. You might as well say that pistons are wear items, or cams, or crankshaft, etc.
430 is offline   Reply With Quote
Old 09-09-2005, 07:03 AM   #12 (permalink)
rbridges's Avatar
Date registered: Nov 2003
Vehicle: 06 corvette coupe
430 - 9/9/2005 7:54 AM
PT
I thought that was crappy, too, but didn't know what MB's stance were on the mounts. I know they appear to wear out relatively quick. Why would something that supports the motor be considered a wear item?
rbridges is offline   Reply With Quote
Old 09-09-2005, 11:08 AM   #13 (permalink)
doctorkaligari's Avatar
Date registered: Sep 2004
Vehicle: SLK230 Limited Editi
Shhhh....don't give them any ideas.
doctorkaligari is offline   Reply With Quote
