Changing the Fuel Filter - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 07-13-2005, 11:11 AM Thread Starter
Date registered: Dec 2003
Vehicle: 1998 SLK 230, 2005 ML350SE
I couldn't find any info about the Fuel Filter location for the 1998 SLK 230.
Any info would be appreciated.
Also, ... how can you change the fuel filter? (i.e. at home)
My car has 67000 km (1998) and from what I read in other posts, .. I think it is time to change this filter !? right?
Cheers
Kaveh
k_afshari is offline
post #2 of 27 (permalink) Old 07-13-2005, 01:03 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
RE: Changing the Fuel Filter
Its under black plastic panel in front of r/h rear wheel parallel to ground.
Panel is held on with 2 nuts (dont overtighten on replacement.)
Filter is in a clamp in tandem with pump.
I reverse up onto ramps,
chock front wheels,
remove panel,
pinch hoses with brake pliers,
undo hose clamps (replace with normal fuel hose screw type)
Undo clamp screw,
remove/replace filter (some petrol will run out)
Replace correct way around.
(Loosen clamps a bit to let any crud in hose run out
before placing back on new filter)
Turn on ignition to bleed system.
Start engine
Check for leaks, stop engine
Replace panel. Do not strip nuts,
Clean up.
etc
bazzle
Bazzle is offline
post #3 of 27 (permalink) Old 07-13-2005, 01:19 PM
AMPM's Avatar
Date registered: Sep 2003
Vehicle: SLK 230
Use Safety glasses and depressurize the system.
And what Bazz said.
Although if you pinch rubber fuel or brake lines it will separate the plies and cause a weak spot.
I Drive Route 4, Southern Maryland's Autobahn.
Slower Traffic Keep Right!!
AMPM is offline
post #4 of 27 (permalink) Old 07-13-2005, 01:23 PM Thread Starter
what do you mean by "depressurize the system" ? how?
Cheers
post #5 of 27 (permalink) Old 07-13-2005, 01:29 PM
Bazzle's Avatar
Bazzle is offline
post #6 of 27 (permalink) Old 01-29-2006, 05:57 PM
Send a message via Yahoo to quest4mike
Hello there.. just bringing up an old forum.. I bought a new fuel filter and had fitting for two hoses. An IN and an OUT. well when i went to change it the one on my 2001 230 had 4 hoses attached.. I went back to the autoshop and everything was correct. i went to a different auto shop and was the same thing.. only 2 spots for a hose IN and OUT. perhaps 2 of these hoses will not be needed.. but was not going to take any chances. any info will be appreciated. Thanks
quest4mike is offline
post #7 of 27 (permalink) Old 02-02-2006, 05:17 AM
16falcon's Avatar
Date registered: Oct 2004
Vehicle: 2002 SLK 32 AMG
quest4mike - 1/29/2006 7:57 PM
The fuel filter I bought from the dealer had spots for all 4 hoses, I am pretty sure you want all 4. There are online parts stores that also sell fuel filters for cheaper than the dealer. Here is a link to one with pictures (I don't know why the price doesn't show) http://www2.discountmbparts.com/part...ilter&dp=false. You can see that all 4 hoses attach like on the original one you have.
16falcon is offline
post #8 of 27 (permalink) Old 02-21-2006, 10:51 AM
TurboZo's Avatar
Date registered: Feb 2006
Vehicle: '00 SLK230 Sport
You probably figured it out by now...but just in case, I noticed that the fuel filters listed on the link above for 98-00 have two connections while 01-04 have four. Probably another change made in 01
Yes, I know the kompressor is a supercharger and not a turbo...
TurboZo is offline
post #9 of 27 (permalink) Old 02-21-2006, 01:03 PM
aceangel's Avatar
Vehicle: 2000 SLK230, Subaru BRZ
I've got one question that has been bugging me about this, the arrow for the fuel filter I bought points in the opposite direction as the old fuel filter. They look exactly the same, but the arrow tells me to insert it the other way from the stock filter. Do I just insert it in the original direction disregarding the arrow?
2000 SLK 230 Sport Designo Copper Edition
ASP Pulley, Bipes Vario Roof Commander, 4300k HIDs, AMG trunk spoiler
aceangel is offline
post #10 of 27 (permalink) Old 02-21-2006, 01:51 PM
Bazzle's Avatar
Bazzle is offline
