Questions on Dyno runs (from first timer), want to get before and after #s for Vaeth V23(more)...
524 views 1 reply 0 participants last post by  Linh
G
The local performance shop that has the dyno (not sure what kind), is offering the following:<br> <br> $75.00 for each run (before and after), if I do the installs.<br> <br> or $100 if they do the install (estimated at 1 hour).<br> <br> If they do the install, they will <br> 1) do the baseline before run<br> 2) leave the car on the dyno, do the install, then<br> 3) do the after dyno run<br> <br> is there anything I should have them do, with this sequence, to get good numbers ?<br> <br>
G
Linh
<br> Turn off the ESP (it will still flash), you will need to seat in the trunk to less up the wheels spin and the most importance thing is that to place the BIG FAN in front of the car. If not, the ECU will retard it timing if the engine is over heating and you loose power.
