I see on the board a lot of poeple have problem with roof not working...
I found oone of those problems and a quick fix to it. It may not affect all of you but it has for me. This can happen when the roof is UP, DOWN or in process or going UP or Down
You know where you pull the shade up to limit your luggage space? to the right of it where the rod rests(as you are looking in the trunk) , there is a little switch there to ensure that the trunk space is cleared for the roof to go down. Sometimes the rod shifts left causing the switch not to engage. if this happens, the light on the console switch will blink FAST. I have had this problem several times in past month or so.
all you u have to do is shift the rod back to the right side making it rest on the switch...or come up with a permanent fix.
Hope this helps some people
99 SLK230 Sport YELLOW...now somewhere in SC
06 Civic with Nav...now somewhere in OH
now 06 Civic SI ....i don't know about this one's where about cuz it went to carmax lol
