Old 06-06-2005, 05:55 PM   #1 (permalink)
ch47pilot's Avatar
Date registered: Jun 2005
Vehicle: 2002 SLK 32 AMG
Transmission and Differential Fluid
I have a 2002 SLK 32 with 40K miles on it. I was told that I should have the tranny and diff. fluids changed for preventive maintenance reasons by a few members in the group. When I talked to dealer he said that the fluids are good for 100K miles and are sealed. Is this correct or should I go somewhere else.
ch47pilot is offline   Reply With Quote
Old 06-06-2005, 07:42 PM   #2 (permalink)
SLKRoadster99's Avatar
Date registered: Apr 2005
Vehicle: 99 SLK230 SPORT
Send a message via AIM to SLKRoadster99 Send a message via MSN to SLKRoadster99
RE: Transmission and Differential Fluid
as far as diff go....
you can use SYNTHETIC 75W-90 weight oil. Lucas/Amsoil/RedLine/Mobile 1 and such
need 14mm Hex socket(or L key) to remove the bolts
if Im not mistaken, SLk32 only comes in Auto?
you should flush it out. I would. I recently changed my trannny(manual) and diff fluid as a preventative maintenance
99 SLK230 Sport YELLOW...now somewhere in SC
06 Civic with Nav...now somewhere in OH
now 06 Civic SI ....i don't know about this one's where about cuz it went to carmax lol
NOW 03 BMW Z4
SLKRoadster99 is offline   Reply With Quote
Old 06-07-2005, 02:10 AM   #3 (permalink)
BlueBenz's Avatar
Date registered: Sep 2002
Vehicle: SLK 230
I had mine done last week, car has 80K. mechanic commented that the diff fluid didn't look too healthy. Certainly won't hurt to have it changed...
BlueBenz is offline   Reply With Quote
Old 06-07-2005, 05:12 AM   #4 (permalink)
430
Date registered: Oct 2002
Vehicle: SLK32, ML430
Change your trans fluid between 50k-60k miles. Don't listen to MB on the fluid durations. A number of people have to their detriment. They have been forced to replace the trans.
430 is offline   Reply With Quote
Old 06-07-2005, 09:35 AM   #5 (permalink)
YellowSLK230's Avatar
Date registered: Sep 2004
Vehicle: '98 SLK230
Send a message via MSN to YellowSLK230
ch47pilot - 6/6/2005 8:55 PM
The factory states the fluids are good for 100K miles. Personally, I would replace the auto trans fluid at 50K miles, using the recommended MB synthetic fluid. Why? Because I have another car with an automatic which the manufacturer recommended replacing the oil at 50K miles; at about 35K miles, the lockup clutch in the torque converter began slipping causing a shuddering vibration in the drive train; very annoying and no doubt causing loads on the rest of the drive train. Their "fix" said the problem was caused by excessive heat causing the oil to partially breakdown; they wanted the entire fluid changed, including removing the pan and filter, and adding a tranny cooler at owner expense.
I simply changed the tranny oil and it took nearly six months for the shuddering to gradually subside, presumably as the clutch facing was worn clean of whatever deposits the oil had made on it. I plan on changing the oil again at 50K and each 25K interval after that, ignoring the longer intervals specified in the owner manual.
I would be less concerned about the differential, because there are no clutches in it to wear and contaminate the oil, and much less heating than in the tranny, and the oil used is a good synthetic. I would leave it alone until 100K, or until a leaking seal, not an unusual occurrance, results in changing the fluid anyway to replace the seal. Most car diffs go 100K miles easily without problems using cheaper non-synthetic hypoid gear oil.
YellowSLK230 is offline   Reply With Quote
Old 06-07-2005, 09:40 AM   #6 (permalink)
Date registered: May 2005
Vehicle: 2001 SLK 320
A local shop near me said that my '01 ~320~ takes 20 quarts of fluid, @ $20 per quart of synthetic Benz trans fluid. Said that the filter change was extra. That said, we were up $500 for a fluid change- The nearest dealer said it was $199.95, including filter and gaskets. As far as leaving the diff oil in until 100k- I changed mine out at 52k, and it looked horrible. Since it only takes a half hour to change, it's senseless not to do it.
prtdvl is offline   Reply With Quote
