I did a search and didn't really come up with anything. When I go to use cruise control it will either not activate at all, or if a lower speed (65 or lower) will turn on but not stay on for more than a short period of time.
The only thing I can think of that has changed is I had new tires an alignment done. Is there a sensor the could of crushed/damagaed? Other than that **KNOCK ON WOOD* the car actually handles and rides much smotther.
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
RE: Help with cruise control
Can't tell you exactly, because I don't have a MT, but they are typically on the pedal arms, near the top. I'll look at my 16 valve when I get home, they should have a similar set up.
Mike, I appologize, there is a cover over the top of the pedals ...
and it's just too cold in the garage to work on the car right now. It's about 18 F out there. Maybe someone in a warmer area can give you a hand. (Please..!)
i have problems on my CC too.. but mine works for like 10 minutes while driving and then turns off if the car shakes hard enough when going to a rough surface.. and sometimes just turns off even when im driving in a perfectly even surface. ive always thought it was the controls on the steering wheel.
AT tranny... will it be the same thing you were talking about?
"So bruce there are no sensors or anything at the wheels?"
Nothing on the front wheels, probable on the transmission as a take off on the speedo, but there still has to be a switch on the clutch and the brake to dis-engage the CC when you use either.
