Is that a good location for a tweeter? Where the shiny wood is? I want to take out that plastic part and install a new tweeter. Tell me what you think.
yea i know about that location. I will put in new tweeters in there. But i want to add two more tweeters since i'm adding some heavier sound...and i figured that, that's the best place to put them...
i'm figuring that not many people on here have tried anything like this correct? I guess i'm going to have to try this myself and post the results later...
Have also seen then located on the pillars running up the side of the windshield. If you add 4 or more tweeters you might run the risk of making the audio system sound a bit harsh and damage the soundstage. Id suggest either putting them in the doors or one of the other locations.
Well destroy might of been a strong choice of words on my part, but it clearly could interfere with it. Since highs are directional having them hitting u from the sides and the front and at different distances from your ears would impact the soundstage. I don’t have any direct experience in the slk w/this problem but I did have it before in a previous car. I installed a second set of tweets, one set on the dash, the other in the stock location near the kick panels I can say when I fired them all up it sounded considerably worse than running either pair w/the system separately. It mudded the sound. But if u do give it a go keep us posted, and tweeters on the mirror panels or windshield supports could give a much better placement than the doors.
