Old 09-30-2004, 04:40 PM   #1 (permalink)
Date registered: Sep 2004
SLK 230 - EC button not working and light indicator is on....
I am new to the forum today. I have an SLK230 yr 98. I often has the AC on, so have not use the EC. Then 2 wks ago I turn it on and the EC light won't come on. After several presses, it works again. I thought it just got stuck. Same thing happen next several days, then now it won't turn on at all. Next day I notice the light indicator when your light(s) go out is on. All the lights are ok, not loose at all, and break lights are ok too. How can I fix the EC and the light indicator. Thanks for any suggestions.
kinaree is offline   Reply With Quote
Old 09-30-2004, 05:57 PM   #2 (permalink)
430
Date registered: Oct 2002
Vehicle: SLK32, ML430
RE: SLK 230 - EC button not working and light indicator is on....
Could be a bad relay.
430 is offline   Reply With Quote
Old 10-01-2004, 01:07 PM   #3 (permalink)
Date registered: Dec 2003
Vehicle: 99 SLK 230 Sport
My EC only works if the fan is set at higher speeds
///Matthew is offline   Reply With Quote
Old 10-01-2004, 09:57 PM   #4 (permalink)
bbsilver's Avatar
Date registered: May 2003
Vehicle: SLK32AMG
///Matthew - 10/1/2004 4:07 PM
0 and . it won't work
1 thru 5 it will turn on.
bbsilver is offline   Reply With Quote
Old 10-04-2004, 11:04 AM   #5 (permalink)
EC button is off and on again, but got the light bulb indicatior fixed...it was the break light housing.
