How to clean silicone spray?? - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 09-29-2004, 02:25 PM Thread Starter
tempoct's Avatar
Date registered: Jun 2004
Vehicle: SOLD: 99 SLK230 K 96 C220 K 06 E200 K
I use the silicone spray to lube the top seal. It works fine but it left some residue on my back windshield (glass). How to clean this mess up? Try Simple Green but doesn't work well.
Too bad, I can't find silicone grease at my local autozone/pepboys.... Anyone know where can I get the grease? Any specific brand I should look for?
tempoct is offline
post #2 of 15 (permalink) Old 09-29-2004, 02:39 PM
AMPM's Avatar
Date registered: Sep 2003
Vehicle: SLK 230
RE: How to clean silicone spray??
xylene
Home depot paint section
Very strong wear gloves and wash hands with soap when done.Do not get on paint or rubber keep on rag.
This stuff will remove silicone from your clothing too.
Oh btw this also removes the glue left behind after you remove tint.
I Drive Route 4, Southern Maryland's Autobahn.
Slower Traffic Keep Right!!
AMPM is offline
post #3 of 15 (permalink) Old 09-29-2004, 02:43 PM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
Did you check SEARS ? when I installed their water softener it came with silicone grease. Also good place to try - Home Depot.
Also I heard good stuff about this product http://www.303products.com/main.php?infopage=protectant
It also suppose lubricate rubber seals to prevent squeaks.
Kirill
Kirill is offline
post #4 of 15 (permalink) Old 09-29-2004, 02:57 PM
AMPM's Avatar
Vehicle: SLK 230
MB has a lubricant for the rubber and seals.
Part # A 001 989 50 51
Wipe down the rubber let it sit for 20 min. then wipe off.
AMPM is offline
post #5 of 15 (permalink) Old 09-29-2004, 03:09 PM
Kirill's Avatar
AMPM - 9/29/2004 5:57 PM
How much ?
Kirill
Kirill is offline
post #6 of 15 (permalink) Old 09-29-2004, 04:43 PM Thread Starter
tempoct's Avatar
Thank you guys.
tempoct is offline
post #7 of 15 (permalink) Old 09-29-2004, 05:34 PM
AMPM's Avatar
Vehicle: SLK 230
Bit pricey at 20.00 but at least you know it wont hurt the rubber.
It solves all the creeks and squeaks.
AMPM is offline
post #8 of 15 (permalink) Old 05-06-2008, 12:02 PM
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup and 2006 ML350
Quoted: 13 Post(s)
I've been researching the whole sunroof maint thing.
This stuff Part # A 001 989 50 51 is damn expensive!
MSRP is like 40 + Dollars and you can get it online at some dealers for around 30+ shipping.
A friend who owns a detail shop mentioned the 303 stuff.
They make what called "Areospace Protectant".
303 Products Inc.: 303 Aerospace Protectant
which is the stuff you would use for the "rubber" seals.
Well if you read their lit, it's actually a different compound.
I wasn't convinced it would be the same as the MB stuff, so I called.
I spoke to a tech guy who said, the 303 stuff soaks into the
seals and restores the normal surface tension, and cleans the rubber, and should result in correcting the sqeaks.
But the MB part is specified as a lubricant.
When you go to order it from a dealer online it's referred to as "grease" but from what I've read, it sounds like it's not grease per se.
Also people have recommended the "Wurth gel stick" I think it's called.
If you go to 303's webpage you can get free sample of everything for $5 shipping, including a 2 oz bottle of the Aerospace Protectant
WHAT EXACTLY IS 001 989 50 51 ?????????
2002 C7 Evolution Orion Blue 2.3L C230 Coupe
Auto-Pano-Oyster Leather-Audio 10
AMG Front bar 22mm-17" Wheels- C32 Brakes- H&R 19mm rear sway
ASP Pulley-Supercharger Muffler Deleted- NGK Copper BKR7E
Supersprint Header-Magnaflow Cat- AR20 Resonator- Remus Muffler
MAF Screen Delete- TB Screen delete
TEIN SS Coilovers -
Clear sides- 2005 tails, Blinkers & Grill- Tinted Windows
Bi-Xenons-Clear Fogs- Clear Side/Stealth Bulbs
Renntech Spoiler
C230 Sport Coup is offline
post #9 of 15 (permalink) Old 05-06-2008, 01:09 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Auto paint shops sell a Silicone remover that wont harm paint. Its used to wipe panels over before painting. Here in Oz its called Prepsol
Bazzle is offline
post #10 of 15 (permalink) Old 05-06-2008, 01:40 PM
irvingst
Guest
Posts: n/a
Quoted: Post(s)
My car was just serviced. I had them lube the top. Thought I'd get a bottle. 49 bucks. Figured I'd wait till it needs it again.
Part # I have is A 000 989 36 60. Small bottle. You run a thin line down the rubber strip. Wipe in with your gloved finger. Let stand. Wipe off. If you think gas or oil is expensive, beware...like I said...small bottle.
