Old 07-06-2004, 09:03 PM   #1 (permalink)
Steve230's Avatar
Date registered: Apr 2004
Vehicle: 2000 Black SLK230 LE
rear view mirror
How can I tell if the rearview mirror is switching to "night mode"? It does not seem to be
Steve230 is offline   Reply With Quote
Old 07-06-2004, 09:19 PM   #2 (permalink)
tempoct's Avatar
Date registered: Jun 2004
Vehicle: SOLD: 99 SLK230 K 96 C220 K 06 E200 K
RE: rear view mirror
Usually, the passenger side mirror is not an autodim mirror. So you can use that one as the reference point. During day time, all mirrors should look quite similar to you. At night, the mirror w/ autodim should be substantially darker.
Mine is not 100% working so don't trust me too much [:)]
tempoct is offline   Reply With Quote
Old 07-07-2004, 05:04 AM   #3 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
There are two sensors on the mirror....................
one in front, one in back. They are located directly opposite of each other. The one inside the car (front) should be fairly obvious, feel for the one in back. With the ignition key in run mode, cover the one in back with your finger leaving the one in front open to ambient light. The sensors should "see" glare and darken the mirrors. If you then cover the cabin side sensor the "glare" goes away and the mirror should lighten.
You should be able to see the color change fairly quickly on the driver's side and cabin rear view mirrors.
The above is most easily done in full daylight.....[;)]
2002 SLK 32,
1987 190E 2.3-16 valve
"A vote is like a rifle: its usefulness depends upon the character of the user."
Theodore Roosevelt
"In any survival situation, you should try to keep your friends alive as long as possible. They stay fresh longer that way.
Unknown
Bruce R. is offline   Reply With Quote
Old 07-07-2004, 07:46 AM   #4 (permalink)
Steve230's Avatar
Thanks I'll try that today. I only have 60 days of warranty left so I'm checking lots of "little"(i.e. expensive) things for proper operation.
Old 07-07-2004, 07:56 AM   #5 (permalink)
Bruce R.'s Avatar
Now is the time to check that kind of thing................
get Benz to pay for it while you still can.[:D]
Old 07-07-2004, 11:38 AM   #6 (permalink)
AMPM's Avatar
Date registered: Sep 2003
Vehicle: SLK 230
Send a message via ICQ to AMPM
Shine a flash light at the sensor if it goes dark it works if it does not it is broke.
I Drive Route 4, Southern Maryland's Autobahn.
Slower Traffic Keep Right!!
AMPM is offline   Reply With Quote
