» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 04-22-2001, 06:52 PM   #1 (permalink)
Larry K.
Guest
Posts: n/a
Does Any One Know The Best Way To Shave The SLK Emblems?
Old 04-22-2001, 07:13 PM   #2 (permalink)
Brian
Guest
Posts: n/a
My SLK emblems don't have hair.
Old 04-22-2001, 09:38 PM   #3 (permalink)
Tim CH
Guest
Posts: n/a
Old 04-22-2001, 09:58 PM   #4 (permalink)
Tim CH
Guest
Posts: n/a
Use a hair drier to make the emblems hot (distance 2"),...
then shift a piece of cardbox between the number/letter and the trunk or fender. Now very carefully lever the emblem from the car. If you were able to remove an edge so that you bring a finger between paint and emblem remove it.<br>
<br>
Should work. Forget the nylon thread methode because you will get paint scratches with it.
Old 04-23-2001, 02:05 AM   #5 (permalink)
Bruce R. - - D.C .
Guest
Posts: n/a
Try dental floss, followed up with the hair dryer method....
the floss cuts the foam rubber without damaging the paint. Once the emblem is off the remaining foam comes off easy with a little heat. A little wax and you're done.
Old 04-23-2001, 09:01 AM   #6 (permalink)
DougM
Guest
Posts: n/a
Mint flavored dental floss works best... :-)
