1995 SL 600, 12 Cyl. 48,000 miles. Small pump (?) right above battery in trunk, cycles on/off for quite a while on engine start. Sometimes doesn't cycle. 4/5 small yellow tube lines come off the top. Duh,,, what is it and why does it cycle intermittently?
Also, SRS light stays on for 2 minutes (approx) after engine start. I did the obvious, cleaned and blew out the seatbelt locks. Any way to reset the light without dealer involvement? Have had the battery disconnected several times in the last couple of years, and have read on forum this could trigger the light as described.
Thanks,
Brainsurgery
Thanks,
Brainsurgery
