Rear Suspension Help - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 06-17-2017, 10:51 AM Thread Starter
ceta4zng's Avatar
Date registered: Sep 2014
Vehicle: 2002 SL500 Silver Arrow
Quoted: 68 Post(s)
Hello all. Strange feeling started on the driver side rear of 2002 SL500. Most dramatic is a slight shimmy that moves the rear of the car from the driver side towards the passenger side when I lift off the accelerator. I am also getting a noise that sounds like finger-flicking a plastic solo cup on some bumps when I drive over an imperfection under the driver side rear tire.
I recently changed the 4 rear control arms on each side (maybe 1000 miles ago) and this started out of nowhere today. I drove about 50 miles didn't notice anything, then on the way home I felt the rear feeling squirrelly. I put the car on the lift (scissor - so suspension hanging) and pulled and shook all the rear suspension parts (and transmission mount) and nothing seems out of sorts - though it looks like my rear sway bar bushings have seen better days.
Any and all help appreciated.
ceta4zng is offline
post #2 of 15 (permalink) Old 06-17-2017, 11:01 AM Thread Starter
ceta4zng's Avatar
Quoted: 68 Post(s)
I'm doing some searching - could this be flex discs?
ceta4zng is offline
post #3 of 15 (permalink) Old 06-17-2017, 12:24 PM
wlb50's Avatar
Date registered: Mar 2013
Vehicle: 1996 SL500
Quoted: 473 Post(s)
It would not be the flex disks. My first thought is the multi links when you say "4 control arms" Are you referring to the multi links ?
As far as I know there's only one control arm per wheel
I'll betthere is a loose one (link) in there now
wlb50 is offline
post #4 of 15 (permalink) Old 06-17-2017, 01:09 PM
Date registered: Mar 2015
Vehicle: 1998 SL 500, 1985 280 SL, 2014 Tesla S, 2009 VW Golf, 1992 300 SL (Sold),1982 380 SL (Sold)
Quoted: 281 Post(s)
I had the same feeling when letting off the gas pedal. See this thread: http://www.benzworld.org/forums/r129...ging-tail.html
I changed both the lower control arm bushings, the 4 links in the multi link suspension and sway bar links. The car drives "like new" now.
Stay flexible - keep smiling
Ruindr is offline
post #5 of 15 (permalink) Old 06-17-2017, 01:24 PM Thread Starter
ceta4zng's Avatar
Quoted: 68 Post(s)
yes - I changed the multi-links
ceta4zng is offline
post #6 of 15 (permalink) Old 06-17-2017, 05:15 PM
robm.UK's Avatar
Date registered: Jun 2009
Vehicle: R129 500 SL 1991
Quoted: 129 Post(s)
It could be your rear subframe mounts. See this link
http://www.benzworld.org/forums/r129-sl-class/2785018-rear-suspension-clunk-creak-2.html
robm.UK is offline
post #7 of 15 (permalink) Old 06-17-2017, 06:28 PM
mahunt's Avatar
Date registered: Feb 2008
Vehicle: 1997 SL600 Brilliant Silver Sport with grey/dark metal interior, 234K miles
Quoted: 130 Post(s)
It's most likely the lower spring bushings that forms the attachment point for the spring link to the carrier hub.
Did you press the old ones out and put in new ones when you rebuild your rear end?
These things wear out all the time.
mahunt is offline
post #8 of 15 (permalink) Old 06-17-2017, 08:55 PM Thread Starter
ceta4zng's Avatar
Quoted: 68 Post(s)
Thank you all for replies. I will change out all the remaining rear suspension patrts. Does anyone one have an explanation of the actiual cause of this behavior? Like 'the 'x' bushing is worn so there is play in the 'x'and when you lift off the throttle, the torque pushes 'x' to 'x' and the rear shifts...
ceta4zng is offline
post #9 of 15 (permalink) Old 06-17-2017, 11:13 PM
Date registered: Mar 2007
Vehicle: 2000 SL320, 2001 CLK320
Quoted: 241 Post(s)
I trust you loaded the suspension up before tightening all the link bolts when you last worked on the suspension.
How many miles on the car?
The front link with the ball joint is called the torque link and if this is faulty then you will get the condition that you indicate in your post. What make are the the new links?
rorypff is offline
post #10 of 15 (permalink) Old 06-18-2017, 05:00 AM Thread Starter
ceta4zng's Avatar
Quoted: 68 Post(s)
Yes, the suspension was loaded when the links were installed. The car has 117k and the work was done at least 1000 miles ago and had seemed fine until yesterday. I believe it was the Meyle kit I installed.
ceta4zng is offline
