I got all my cylinders back in from Top Hydraulics and installed, and having forgotten to do the fluid change PRIOR to changing out the cylinders, as any half wit would have done, I have now sucked out the fluid from the pump and there it is next to some fresh fluid. I also have some gunk at the bottom of the reservoir. Otherwise, everything looks ok.:|
So it appears I need to pull that reservoir off and will do my due diligence, but its always helpful to get some freedback from the community. Will it all go back together with no additional parts needed? I kinda need that to happen so I can get the cylinders tested prior to my top replacement week after next. Otherwise, I'm running to the dealer or getting things over-nighted. What think you? Take off that gear clamp and it will all come together? Anything else I should be aware of? I have enough fluid to do about 3 fluid flushes, so things should come quite clean.
