Difficuty aligning the sunglass compartment with the locking mechanism - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-16-2017, 06:22 PM Thread Starter
Date registered: Feb 2017
Vehicle: '92 300 SL, '00 E430, '14 E350
I could use some help with aligning my glove box/sunglass compartment on my '92 300 SL after I replaced the center A/C vent, and in the process broke the brittle sunglass compartment upon removal. Was able to get a replacement part, but unable to align it with the lock. When I shut the lid and I depress the lock, the lid does not open. I went into the slot underneath with a pick tool to depress the locking mechanism to get it open again, but after a few times I gave up. My MB guy says I need to remove the passenger side knee bolster and remove the pass. side airbag to get to the lock and align it from the right. That seems like a lot of billable hours to me. I know the screws in the back of the compartment align the unit, but it is seemingly impossible to get it aligned with the lock? Has anybody experience this issue before?
Tks,
Joe
Windancer is offline
post #2 of 6 (permalink) Old 02-16-2017, 10:56 PM
Richard F's Avatar
Date registered: Feb 2014
Vehicle: 1994 SL320
Quoted: 389 Post(s)
Mine came out and went in ok, a little fiddly so persevere before further dismantling.
One of the (few) benefits of living in a cooler climate is our plastics don't suffer as much.
jimdollar likes this.
Richard F is offline
post #3 of 6 (permalink) Old 02-17-2017, 11:26 AM
isthenew's Avatar
Date registered: Jan 2014
Vehicle: Mine now: 1997 SL320. Past: 1996 SL320. But also watch a 2013 E350 Cabrio.
Quoted: 170 Post(s)
Your mechanic is waaaaaaaay off. What's most likely happening is the part on your lock isn't lining up properly with the part on your sunglass compartment spring.
Here, pull the sunglass case and the lock out and play w/them for a couple minutes:
Richard F and throwbookatface like this.
isthenew is offline
post #4 of 6 (permalink) Old 02-19-2017, 08:55 AM
Chewa's Avatar
Date registered: Jun 2015
Vehicle: 2007 E class Estate 280CDI (S211) 2000 SL 280 V6 (R129)
Quoted: 42 Post(s)
I took mine out so that I could run my Parrot ipod lead into it. Meant that the a/c vents came out too.
When I replaced the sunglasses case after this it did stick a bit. However, I found that by adjusting the two screws at the rear of the sunglasses compartment (the ones which hold it ina and which are used line up the lid with the rest of the dash) I got it to release reliably.
Takes a bit of trial and error, but works fine.
plus je vois les hommes, plus j'admire les chiens
Chewa is offline
post #5 of 6 (permalink) Old 02-20-2017, 09:23 AM
isthenew's Avatar
Quoted: 170 Post(s)
This is interesting. I know I've used those 2 screws to adjust the sunglass case depth because down here the dash can swell and if you go too deep the case won't open; it'll just catch on its way up.
isthenew is offline
post #6 of 6 (permalink) Old 02-20-2017, 12:52 PM
Date registered: Mar 2015
Vehicle: 1998 SL 500, 1985 280 SL, 2014 Tesla S, 2009 VW Golf, 1992 300 SL (Sold),1982 380 SL (Sold)
Quoted: 269 Post(s)
Yes, it's described that way in the WIS. The two screws are for adjusting the locking mechanism. First time I removed it I didn't get the screws sufficiently in, and had a very hard time getting the lid to release. A couple of turns and it did the trick.
Stay flexible - keep smiling
Ruindr is offline
