Recent discussions of the Overload Protection relay got me curious as to what it protects and how it works--here goes.
It protects various control modules (ABS/ASR, ECU, etc.) from seeing sustained (more about this below) voltages in excess of 22 V.
Here is a diagram of the 9-pin unit, from the 2012 WIS (not the best quality but it is what it is):
In normal operation:
Examining "what can fail" in the OVP relay; should Z1 become open overload protection would be lost, if it were to short fuse F1 would blow as soon as replaced. Should one or both of K1 and K2 fail (bad coils or contacts) power to the control modules would be compromised.
If a relay coil were to fail there would be no power to the control modules, and obvious failure, however should either relay's contacts wear and become "resistive" it could result in the modules being voltage starved to behave oddly.
This, the above exercise, is the sort of thing that happens when a retired engineer is left home alone on a dreary afternoon...
- Terminal 1 (pin 30 in the relay unit) is supplied a constant +12 V, this power is passed through F1 and applied to the relay's + terminals, to terminals 4 and 5 (pin 30a), and to the cathode of Z1--a 22 V Zener diode;
- When the ignition switch is ON terminal 3 (pin 15) is supplied with +12 V switching the transistor ON and activating relays K1 and K2;
- The relays then supply power to the control modules via terminals 2, 6 , 7 and 9 (pins 87E and 87L);
- Should the constant 12 V supply exceed 22 V Z1 will shunt the excess voltage to ground--until the shunt current [edit] plus normal load controlled by K1 [/edit] exceeds 10 A (the value of F1) long enough for F1 to react (probably 50 to 200 ms). If the overvoltage lasts that long fuse F1 will blow--removing activating voltage to relays K1 and K2, and of course cutting power to the control modules.
