1998 Sport Steering Wheel Interchangeable With W140 Wheel? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 07-25-2013, 06:32 PM Thread Starter
Hahn92's Avatar
Date registered: Dec 2009
Vehicle: 1998 SL500 Pano/AMG PKG, 1997 S500 V12 PKG
Quoted: 4 Post(s)
So I went to my dealer today to swap out my 1998 SL500 sport steering wheel for a 1996-1998 W140 wood steering wheel. I got bad news from the service advisor. I have no idea how, but somehow someone tampered with the airbag in the past. The two T30 torque screws that hold the airbag in place are not accessible because there seems to be broken drill bits in each socket! I was told the only way to remove the steering wheel is to cut the sides out of the airbag. It's about $200-$300 in labour, but thats not the issue.
The problem is the parts department and techs were not 100% sure that the W140 steering wheel would fit. If I cut the old steering wheel off..it's deemed useless. The shop foreman said that the steering wheel would most likely fit, along with the "single-stage airbag". The risk is I won't have horns that work. oh and something about a clock spring..which shouldn't be an issue. They cant guarantee anything, so I feel like I'm gambling. The service rep told me to sleep on it and come back, they took almost an hour assessing the situation and answering my questions, no charge of course.
Can the horns work on the W140 wheel (single push horn) after swaping out the factory sport wheel with button horns? What are the connections like? Compatible?? I can't drive without horns!
Any advice is appreciated!
ID:	529395   Click image for larger version
ID:	529396   Click image for larger version
ID:	529397   Click image for larger version
Hahn92 is offline
post #2 of 11 (permalink) Old 07-25-2013, 07:44 PM
Poundy's Avatar
Date registered: Aug 2010
Vehicle: 1992 500sl Pano, 1999 CBR 1100XXxx Super BlackBird "The Beast", Jaguar X Type
Quoted: 205 Post(s)
It appears to me the one you intend putting on is complete in every way. If that's so, it should only be a matter of plugging the the air bag and the horn to it. If I remember correctly there is also 2 horn leads on the earlier pad anyway.
The worst case scenario is that you will have to get another air bag if you have to go back to the original wheel. But the non removal problem needs to be addressed anyway. It's Murphy's Law that you will need to remove the wheel at some stage, so really it's a win, win situation
Nice wheel the same as I put on my 92
Life begins at 240 kph!
My Sold 1992 Upgrade Photo's
Poundy is offline
post #3 of 11 (permalink) Old 07-25-2013, 07:51 PM
Undercover Moderator
SL BRABUS's Avatar
Date registered: Mar 2007
Vehicle: SL BRABUS 5.8 Silver Arrow, SL BRABUS B11, S Class diplomat ride, ML55 wife war horse grocery getter
Quoted: 195 Post(s)
Yes, it interchangeable.... If you get the steering & airbag.....
Horsepower: enough power to go from point A to point B
Torque: enough to get the car moving
0-60 mph: not in a rush
0-1/4 mile: about 5 minutes @ 2mph because no need to showoff
Pictures of my SL collection & Pictures of my S Class ride
My favorite topic, What kind of watch do you guys wear with your Benz...??
SL BRABUS is offline
post #4 of 11 (permalink) Old 07-26-2013, 10:04 AM
sapphirexae's Avatar
Date registered: Nov 2012
Vehicle: 2002 Silver Arrow Pano
Quoted: 144 Post(s)
Brabus is correct, they are fully interchangeable!
sapphirexae is offline
post #5 of 11 (permalink) Old 07-26-2013, 10:05 AM Thread Starter
Hahn92's Avatar
Quoted: 4 Post(s)
okay! Thanks guys! I'm gonna do it
Hahn92 is offline
post #6 of 11 (permalink) Old 07-26-2013, 10:34 AM
Quoted: 144 Post(s)
I swapped my standard 96' wheel for the 99+ style. It was a direct swap, the only thing tricky was the bolt that mounts the steering wheel itself. They are of very, very thin aluminum and strip if you just look at them. Other then that, it was a crazy easy job (and I'm not at all mechanical)!!
post #7 of 11 (permalink) Old 03-10-2014, 09:31 AM
Premium Member
Date registered: Jan 2014
Vehicle: 1996 SL500
Quoted: 63 Post(s)
Premium Member
I have 1998 SL500 and the steering wheel makes squeaking noise when I drive. A little grease spay into crevice did not work and so I tried to pull out the wheel. But somebody said I need Torx T25 to unscrew two bold behind wheel but it does not seem to be the right size. Anyone give me a tip? T30 ?
ericahn is offline
post #8 of 11 (permalink) Old 03-10-2014, 10:42 AM
R129 HTT Founder Member
Pete S's Avatar
Date registered: Sep 2012
Vehicle: 040 1996 SL500, 775U 2008 R350 4Matic
Quoted: 921 Post(s)
T30 on my 1996, no doubts about it as I just swapped out wheels myself.
1996 SL500 Photo Collection Updated 01-14-16
Mercedes aren't for people who want to have one, it's for people who can have one.
Pete S is offline
post #9 of 11 (permalink) Old 03-10-2014, 12:08 PM
Date registered: Dec 2013
Vehicle: SL280 1993
Quoted: 5 Post(s)
Before pulling the wheel out check rubber steering shaft housing (located near the pedals). My wheel squeaked too when rotated and I sprayed with silicone every hole in the wheel I could reach - no result. After that I tried WD-40 on the rubber mounting and voila - silence!
Gvadalahara is offline
post #10 of 11 (permalink) Old 04-21-2017, 05:22 AM
Firewater's Avatar
Date registered: Jan 2009
Vehicle: 1985 500 SEC EURO AMG/LORINSER; 1988 560SEL, 1995 S500 Sonderschutz
Quoted: 179 Post(s)
Sorry for raising this from the dead but I just bought a steering wheel from a 1999 SLK 300 which looks just like the SL wheel posted here but black. Will it fit my W140 1995 S500?
LUBE YOUR THROTTLE LINKAGES!
"A little neglect may breed mischief: for want of a nail the shoe was lost; for want of a shoe the horse was lost; and for want of a horse the rider was lost." -Benjamin Franklin
Firewater is offline
