98 SL 600 Engine light on - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 01-16-2013, 07:23 PM   #1 (permalink)
Date registered: Sep 2012
Hi togehter,
Last week I was driving with my SL 600 and suddenly the check engine light, the BAS/ASR light, and the Water temperature light came on at the same time and the rpm counter went to zero.
Here are the failure codes after the quick test
ME1R
P1747 CAN from ETC faulty
P1384 Left front knock sensor
P0432 Left TWC effiency below threshold
P0155 Left O2S 1 (before TWC) (G3/3) heater circuit malfunction
P0160 Left O2S 2 (after TWC) (G3/5) no activity detected
P0161 Left O2S 2 (after TWC) (G3/5) heater circuit malfunction
P1149 Left pressure sensor (B28/1)
P0153 A Left O2S 1 (before TWC) (G3/3) correction range exceeded
P0153 B Left O2S 1 (before TWC) (G3/3) slow response
ESP
C1142 Lateral acceleration
-004 sensor B24/2 or sensor B24/15 Plausibility
C1022 CAN communication
-013 interrupted with ME N3/10 right
C1120 ESP yaw rate
-001 sensor N64 or B24/15
BAS
C1025 CAN signals
ABS not available
ADS
C1122 Body acceleration sensor RF B24/4
C1110 Wheel speed signal LF
ETC.6
132 Occasionally Engine management CAN communication or eng. temp. implausible
148 Occasionally Torque converter lock-up clutch, unaithorized locking
135 Occasionally CAN communication disturbed with: Engine management
RFL
B1102 IR signal wire from left door IR receiver unit A26/1
B1103 IR signal wire from right door IR receiver unit A26/2
RST
114 Limit switch S84/4 Soft top close
124 Limit switchSignal illogical
065 Vehicle speed signal (VSS) implausible
ATA
012 Alarm activated via ignition/starter switch S2/1
020 LF door actuator S47 No ground
IC
B1040 CAN communication fault to engine control module
B1471 Outside temperature
-002 indicator temp. sensor B14
AAC
B1227 Outside temperature sensor B10/5
B1417 Duovalve Y21
B1231 Engine coolant temperature sensor B11/4 comes from engine control module
B1419 Electromagnetic clutch A9k1
Does anybody know what my problem could be?
nesch18 is offline   Reply With Quote
Old 01-16-2013, 07:27 PM   #2 (permalink)
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
Looks like everything happens all at once. But some codes may be triggered by others.
I would start by clearing all codes and deal with the first one that comes back.
RKH is offline   Reply With Quote
Old 01-16-2013, 07:30 PM   #3 (permalink)
MercedesTheBest's Avatar
Date registered: Jul 2012
Vehicle: 1995 SL500, 2012 E550 2 Door Coupe, 2012 GLK350
what year is it? if it is a 93-95 it could be the wire harness. i would check for cracking insulation around the wires. it normally would cause a lot of codes to come up all of a sudden.
1995 SL 500 Mercedes Benz
2012 E 550 2 Door Coupe Mercedes Benz
2012 GLK 350 Mercedes Benz
2014 ML 63 Mercedes Benz (on order)
2002 CL 500 Mercedes Benz - (sold)
1984 Camaro 5.0L High Output Chevrolet - (sold)
1982 CD 300 Turbo Diesel Mercedes Benz - (sold)
MercedesTheBest is online now   Reply With Quote
Old 01-16-2013, 07:36 PM   #4 (permalink)
somebody told me the problem could be a CAN connection plug. Is there a cable coming out of the transmission to a control unit?
Old 01-16-2013, 07:37 PM   #5 (permalink)
1998
Old 01-16-2013, 07:39 PM   #6 (permalink)
RKH
RKH's Avatar
'98 would have the electronically controlled transmission
Old 01-16-2013, 07:41 PM   #7 (permalink)
that would mean?
Old 01-16-2013, 07:47 PM   #8 (permalink)
RKH
RKH's Avatar
That means you transmission is electronically controlled, so to answer your post #4 : there would be cable connected to it.
Old 01-16-2013, 07:56 PM   #9 (permalink)
But there should be no oil running along that cable? or could that happen?
Where does this cable go?
By the way Thanks for all your help!
Old 01-16-2013, 07:57 PM   #10 (permalink)
RKH
RKH's Avatar
Why would there be oil ? it is electrical cable.
Bookmarks
